Gas law, how to fine the final T and Final P?
The discussion focuses on calculating the final temperature and pressure of a reaction involving hydrazine (N2H4) and oxygen (O2). The final temperature is derived by converting the mass of N2H4 to energy using its specific heat capacity, resulting in a temperature of 508K. For pressure, the ideal gas law (PV=nRT) is applied, where 20 moles of N2H4 react completely with 60 moles of O2 to produce 80 moles of products. The confusion arises regarding the stoichiometry of the reaction, emphasizing that the chemical equation dictates the ratios of reactants and products, rather than simply adding moles. Understanding the limiting reactant concept is crucial for accurate calculations in chemical reactions.
nevada2012
i don’t understand how they got this answer
can you please explain the steps
needed to fine the Final T and How the final P was found.
thanks
N2H4 + 3O2 ==> 2NO2 + 2H2O
assume there are 60 moles of O2, what is the final T and P
V = 20L
T1 = 290K
n (N2H4) = 20
Cp = 57 kJ/C
Hc = 194.1 x 105 J/kg
final T:
20 mol N2H4 * 32g N2H4 / 1mol N2H4 * 1kg / 1000g =0.640 kg N2H4
0.640kg N2H4 * 194.1 * 10^5 J/ Kg N2H4 * 1kJ/ 1000j =12,420 KJ
12,420KJ * 1c/57Kj= 218C T f = 290K+218K=508K
Final P : PV=nRT ==> P=nRT/V
n=20 moles N2H4 react with 60 mole of O2 sp no left over O2
20N2H4====> 40NO2 + 40 H2O =80moles
R= 0.0821L*atm /1mole *K
T=508K
V= 20L
P=nRT/V
= 80mol * 0.0821 L*at, / 1mol K * 508K * 1/20L = 167atm
Chemistry news on Phys.org
You want to fine the final T for speeding :D ?
Anyway, what specifically don't you understand about this? And are you sure that Cp and not Cv is given?
ok i figure out the first step.
all that they did was converted from
moles to g to kg then multiply the specific heat then convert to J then to KJ then to C and then to K
now i am confuse as to how they found the P
i understand that the equation is pv=nrt which becomes p=nrt/v
but they did this
N= 20 moles N2H2 react with 60 mol O2 , so there is no left over O2
what i don't understand, is what do they mean by left over O2?
so then it continues with
N2H4--->40NO2 + 40H2O = 80 moles
i don't understand how they got the second equation N2H4--->40NO2 + 40H2O = 80 moles
can't i just add 60 and 20 to get the 80moles?
thanks
The (properly equilibrated) chemical equation for the reaction gives you the proportions in which the reactants react with each other. In your case, for each mole of N2H4 you need 3 moles of O2 (thrice the amount of N2H4). That will give you 2 moles of NO2 (twice the amount of N2H4) and two moles of H20 (twice the amount of N2H4). If you have 20 moles of N2H4 you need 20*3 = 60 moles of O2, which is exactly what you have. Had you had 100 moles of O2, there would be 40 moles of O2 left over. Knowing that 20 moles of N2H4 will react, you know that you'll have 20*2 = 40 moles of each one of the products. Since 40 + 40 = 80, you'll end up with 80 moles of gas after the reaction finishes. Once again, had you had 100 moles of O2, you'd still have 80 moles of product by the end plus 40 moles of O2. In this reactions the total number of moles is conserved (1 + 3 = 2 +2 ), so it's easy. There are several reaction where moles of gas are created or destroyed. Most explosives, for example, involve reactions that produce huge amounts of gas, which will expand, creating massive destruction.
A chemical equation gives you the proportions of reactants you need and the proportion of the products you will obtain. That's what you need to keep in mind. You should always measure everything with respect to the quantity of limiting reactant (the reactant there's not enough of).
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
