MisterDynamics
- Messages
- 16
- Reaction score
- 2
Is this gas turbine engine compressor discharge air temperature calculation relatively accurate?
Problem:
Calculate the compressor discharge air temperature in ºF of the following gas turbine engine compressor core specifications.
Gas Turbine Engine Compressor Core Specifications:
75% Compressor Efficiency
23:1 Compressor Pressure Ratio
Outside Air Temperature = 65º F
Solution:
Formula:
Tout = [Tin] + [(Tin) x ((PR)^0.263 - (1)) / (CE)]
Tout = Compressor Discharge Air Temperature in ºR
Tin = Outside Air Temperature in ºR
PR = Compressor Pressure Ratio
CE = Compressor Efficiency
ºR = [(ºF + 460)]
Tin = [(65 + 460)] = 525º R
PR = 23
CE = 0.75
(23)^0.263 – 1 ====> Compressor Pressure Ratio to the 0.263 power minus 1 = 1.28
1.28 x 525 ===> 1.28 multiplied times outside air temperature in absolute temp R = 672
672 / 0.75 ===> 672 divided into compressor efficiency in decimal form = 896
896 + 525 ===> 896 plus outside air temperature in absolute temp R = 1,421
Compressor Discharge Air Temperature = 1,421º R
1,421 – 460 ===> 1,421 degrees R absolute temperature minus 460 = 961º F
Compressor Discharge Air Temperature at given compressor specifications = 961º F
----------------------------------------------------END------------------------------------------------------------
Problem:
Solution:
Formula:
ºR = [(ºF + 460)]
PR = 23
CE = 0.75
