Gauss Law? Average charge density
10 replies · 4K views
Roodles01
Hi. A cylinder of radius r & length L whose charge density distribution is given by
ρ = C/2 * r3
where r = radial distance in cylindrical coordinates
C = constant
show that the average charge density ρbar = a3 C / 5
Gauss differential law div E = ρ / ε0
div E = 1/r * ∂/∂r * (rEr) + 1/r ∂E∅/∂∅ + ∂Ez/∂z
Hmmm! Not really sure where to begin with this.
Not sure if it's to do with stuff as "difficult" as equations above.
* * Scratches head. Help please! * *
ρ = C/2 * r3
C = constant
What is a?
Also it is not clear whether: ρ = C/(2*r3) or ρ = (C/2)*r3
What does average charge density mean? Can you determine the total charge in the cylinder?
AM
Ah. Detail.
Get it right, me.
a is radius of cylinder
r is radial distance in cylindrical coordinates
first equation is
ρ = (C/2)*r3
As far as "average" goes I'm assuming to be the mean.
Hope this clears things up.
Roodles01 said:
Ah. Detail.
Get it right, me.
first equation is
ρ = (C/2)*r3
Ok. But give us an expression for it.
AM
Hint: average charge density is: total __________/ total _________
AM
Roodles01 said:
I'll try total charge / total area.
Why area? This is a solid cylinder. Hint: what are the units of mass density? By analogy, what are the units of charge density?
AM
Aha! It's volume.
Density has units of mass per unit volume such as g/ml
so charge density must be units of charge per unit volume such as coulombs/ m3 for volume such as the Gaussian surface (cylinder)
Thanks I shall post again soon.
Roodles01 said:
Aha! It's volume.
I am not sure why you are referring to Gauss' law here. You are not calculating the electric field so there is no need to think of the cylinder surface as a Gaussian surface for this problem. You are just trying to find the total charge and total volume.
AM
Ah! It all clears.
Clouds have gone. It's not just about algebra after all.
ρ = charge density distribution which is distribution at a single point, so have double integral
Roodles01 said:
Ah! It all clears.
You don't really need the double integral. You know that the cylindrical surface with radius r and dr thick has volume 2πrLdr. So you just have to integrate from r=0 to r=a to find the charge.
[itex]q = \int_0^a ρdV =\int_0^a ρ2\pi rLdr[/itex]
Then it is just a matter of dividing by the total volume.
AM
