Gauss Law Problem with Cylinders
The discussion centers on calculating the electric field inside an infinitely long, non-conducting cylinder with a uniform volume charge density ρ for the region where 0 < r < R. The correct formula for the electric field in this scenario is E = ρr/2εo, derived using Gauss's Law (EA = Qin/εo). The confusion arises from the incorrect application of the Gaussian surface and the misinterpretation of the charge enclosed, leading to an erroneous formula of ρr^2/2εoR. The participants clarify that the charge enclosed (Qin) relates only to the volume within the Gaussian surface.
  • Understanding of Gauss's Law (EA = Qin/εo)
  • Familiarity with electric fields and charge density concepts
  • Knowledge of Gaussian surfaces and their application in electrostatics
  • Basic calculus for integration over volume
  • Study the derivation of electric fields using Gauss's Law in various geometries
  • Learn about charge density types: volume charge density, surface charge density, and linear charge density
  • Explore the implications of different Gaussian surfaces in electrostatics problems
  • Review examples of electric field calculations for cylindrical and spherical charge distributions
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electrostatics and electric fields.
physics16102
An infinitely long, non-conducting cylinder of radius R carries a uniform volume charge density ρ. Find the magnitude of the electric field for 0 < r < R
EA=Qin/εo
I am debating whether the answer should be ρr^2/2εoR or ρr/2εo.
I said E(2πRL)=(ρπr^2L)/εo and solved to get ρr^2/2εoR.
I was confident in my answer but then found the same problem in the book, but it asked to find E at distance r from axis, where r<R. The answer to this was ρr/2εo. Can someone explain the difference between these two problems, if there is one. They may be exactly the same and my calculation is wrong, but I am confused over the two
If you want to find E at r<R your Gaussian surface is a cylinder of radius r.
ehild
Since r<R, R will never appear in the equation since my dA vector relates to r and Qin also relates to r. I would simply replace R with r in my equation and solve, yielding ρr/2εo. Is this logic correct?
I think I just failed to remember that in the basic form of the equation, you are integrating over the Gaussian surface. But does Qin relate charge enclosed by the Gaussian volume drawn or by the entire volume in question?
Qin is the charge of volume enclosed by the Gaussian surface.
ehild
physics16102 said:
So I would get E(2πrL)=(ρπr^2L)/εo and E=ρr/2εo.
But this website says I am wrong so I am now very confused
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elecyl.html#c3
It is saying for r<R, E should be completely different. Can someone please clear this up?
In that formula at hyperphysics, E is given in terms of lambda, the charge per unit length. In your problem, the charge per unit volume (rho)was given. Compare your new result with that you cited from your book in your first post.
ehild
When I calculate it, I get ρr/2εo.
But the website above says something different, so I am clueless as to what to put if this problem were on my test tomorrow(today lol).
We posted at the same time. I did not notice that. I'll change my calculation and see what I get
See my previous answer.
ehild
I've concluded that the calculation is correct for my problem and it is ρr/2εo.
But, I don't understand where they get the R^2 in the bottom of their equation on hyperphysics. It has to come from the A part of EA=Qin/eps, but how? Shouldn't A always be in terms of the gaussian surface, which has nothing to do with R.
nevermind, found the link that explains it. I would never come up with that on my own but at least I now understand the difference and why it is there
  • · Replies 26 ·
