How do you calculate the electric field and voltage for a charged sphere?
The discussion revolves around calculating the electric field and voltage for a uniformly charged insulating sphere with a specified charge density. Participants explore the application of Gauss' Law to determine the electric field both inside and outside the sphere, as well as the total charge and voltage at various distances from the sphere.
  • Participants discuss the application of Gauss' Law, questioning how to express the electric field and charge in terms of the radius and charge density. There are inquiries about the relationship between charge density and total charge, as well as how to approach the calculations for different regions (inside and outside the sphere).
The discussion is active, with participants collaboratively deriving expressions for the electric field and clarifying concepts related to charge distribution. Some participants express understanding of the derived formulas, while others seek further clarification on the implications of their calculations in different scenarios.
Participants are working within the constraints of a homework assignment, focusing on specific parts of the problem while adhering to the requirement of not providing complete solutions. There is an emphasis on understanding the differences in electric field behavior based on the position relative to the sphere's radius.
Cryphonus
A sphere of radius R=10 cm made of insulating material has a uniform charge density p=100 C/m-3
a)Find the magnitude of the electrical field at a distance r<R, using Gauss' Law.What is the value of the electric field at r=5 cm?
b)What is the total charge on this sphere?
c)Find the magnitude of the electric field at a distance r>R using Gauss' Law.What is the value of the electrical field at r=10cm? At r=20 cm?
e)Take the voltage at r=0 to be 0 Volts.Find the Voltage V(r) at any r by integrating the Electrical field E(r) along the radial direction.
Gauss' Law= [tex]\oint[/tex]E.ds=Qinside/E0 (permittivity constant)
I managed to do b) since the density is provided to us we only have to find the Q from d= Q/V, V is 4/3Pi R3... but i certainly do need help with other questions.
I will start by helping you with part (a).
on the left hand side of Gauss' equation we are able to move the E field through the surface integral. why?
side note: (are you in calculus based physics or algebra based?)
We are able to move the E field through the surface integral because the electric field is parallel with the surface vector of that area am i right?
(Calculus based physics)
precisely!
now, we can modify our equation a little.
[tex]E\oint{dA}=\frac{Q_{en}}{\epsilon_0}[/tex]
what is [tex]\oint{dA}[/tex] equal to?
[tex]\oint{dA}[/tex] equals to surface area i assume?
yes, now how would one express the charge in term of the charge density?
(remember that we desire an express in terms of the radius)
well, charge density should be equal to total charge/Volume,,, and volume can be expressed as a function of the radius.
right, so this is our expression:
[tex]E4\pi r^2=\frac{\rho 4 \pi r^3}{3\epsilon_0}[/tex]
does this make sense to you?
To be honest i haven't seen this around before, would be glad if you can tell me the way that you calculated such a formula?
We just calculated it together:
[tex]E[/tex]= electric field
[tex]4 \pi r^2[/tex]= surface area of a sphere =[tex]\oint dA[/tex]
[tex]\rho=\frac{Q_{en}}{V_s}[/tex] (where V is the volume of the sphere.)
so [tex]\frac{\rho 4 \pi r^3}{3}=Q_{en}[/tex]
what doesn't make sense?
right! i got it now. its all clear now :)
So how are we going to plug this to the question. It feels like there is still things that I am missing ?
(sorry I went out to eat, I am back now for 15mins then I have class just f.y.i)
nothing is missing just plug in what is known and solve for the E field.
Note that this is the E field for only 0<r<R
thats ok =). I have a question about that.What changes when we take a point that is greater than our radius, and when we take a point that is smaller than the radius, which is actually within the sphere.
The charge enclosed changes from linear to constant.
When: 0<r<R
the charge enclosed is a function of the radius. This is quite intuitive because the closer we get to R the more charge we have enclosed.
When: R<r<infinity
the charge enclosed is a constant function. This is also quite intuitive because there is no charge outside the sphere which would add to the enclosed charge.
Ok that makes sense except 2 points;
First how are we going to find the formula for the other situation, what do we need to change?
Second one;
For the situation, R<r<infinity , this actually means the point we are considering is somewhere out of the sphere.Are you saying that the E field is constant for all the points that is left out of the sphere?, shouldn't it be decreasing with proportional to 1/d2
Your first point:
we are going to find the formula for the other situations in the same manner. We need to change the charges dependence on r.
point two:
I am not saying the E field is constant outside of the sphere. I am saying that the enclosed charge is constant outside of the sphere. You should be able to differentiate between these two things.
(Note: the E field will fall off inversely proportional to the radius squared)
Alright i understood.Thanks for all the help
My pleasure ^^
  • · Replies 18 ·
  • · Replies 16 ·
