Gaussian wave packet in position space
8 replies · 3K views · last reply
KFC
Hi all,
The Gaussian wave packet is widely discussed in the text. I got the following expression for wave packet in momentum space
##\psi(p, 0) = A \exp\left[-(p-p_0)^2/ (2\sigma_p^2)\right]##
with ##A=\sqrt{2\sigma_p/\sqrt{2\pi}}##
As my understanding, the corresponding wave packet in position space should be inverse Fourier transformation of ##\psi(p, 0)##. I plot the ##\psi(p, 0)## in matlab, I saw the Gaussian profile. But when I take the inverse Fourier transformation ifftshift(ifft(psi)), I saw something of the order ##10^{-6}##. I have no idea why is it.
KFC said:
I saw something of the order 10−610^{-6}
So long as it's normalized, what's the problem? It depends on how you set the parameter values anyway.
The problem is after the numerical transformation, all samples for the packet is about ##10^{-6}## instead of ranged from 0 to ##10^{-6}## that means it is almost zero everywhere. Let me restate my question with some code and data. I think I made an mistake in the first post, here is the Guassian in momentum
\psi(p) = \sqrt{\dfrac{1}{\sqrt{2\pi}\sigma_p}}\exp\left[-\dfrac{(p-p_0)^2}{4\sigma_p^2}\right]
If you integrate this in mathematica, ##\int_{-\infty}^{+\infty} |\psi(p)|^2dp = 1##. I also tried to find the wave packet in position by inverse Fourier transformation, I got
\phi(x) = \sqrt{\dfrac{2\sigma_p}{\sqrt{2\pi}}} \exp\left[-\sigma_p x^2\right]\exp(ip_0x)
and ##\int_{-\infty}^{+\infty} |\phi(x)|^2dx = 1##. Plotting those functions with ##p_0=0, \sigma_p=1##, we observe that ##|\psi(p)|^2## with minimum and maximum as 0 and about 0.9; the minimum and maximum for ##|\phi(x)|^2## is about 0 to 1.2
Now doing numerical evaluation by matlab, I try
p0 = 0;
sigma_beta = 1;
psi = sqrt(1/sqrt(2*pi)/sigma_beta);*exp(-((p-p0).^2)/(4*sigma_beta^2));
phi = ifftshift(ifft(psi));
plot(abs(phi).^2);
The range for the plot is about ##10^{-5}## and is we sum over the ##|\phi|^2##, I've got 5.9921e-04 while the sum of ##|\psi|^2## gives 1. See the attachment (don't know why it upload twice and seems I cannot remove one of them)
  • Line plot of |phi|^2 against x from -100 to 100, with a multiplier of 10^-5 on the vertical axis. A single narrow red peak centred near x = 0 reaches about 4.8 x 10^-5, and the curve is near zero elsewhere.
  • Plot of |φ|² against x from -100 to 100, showing a single narrow red Gaussian peak centred near x = 0 with maximum about 4.8 × 10⁻⁵ and near-zero values elsewhere.
I haven't checked your calculation, but I just want to confirm, have you considered that ##p=\hbar k##? Forgetting this may also affect the scaling of the wavepacket in position space, and hence the numerical integration.
Thanks for your reply. I rescale the system with ##\hbar=1##. Moreover, in both analytical calculation (mathematica) and numerical one (matlab), I have the same scale (##\hbar=1##). so the result should be identical. But they are not. My question is why the numerical one doesn't give the same one from analytical expression.
Your analytic formulas seem to be correct, provided that you set ##\hbar=1##. So you have a MATLAB problem, not a physics problem.
Do you simply sum up the components, or do you also multiply by ##dx## or ##dp##?
While ifft(fft(psi)) should recover the original psi, I don't know what normalization of the single action of fft or ifft should be. From what I can gather from the manual, there is a ##1/N## factor in ifft, with nothing for the forward fft, so that might be the origin of the scaling you see.
Thanks for reply. Yes, I sum up all components and multiply it with dx or dp to test normalization.
For fft part, yes, it has the 1/N in front of series, I've already taking that factor in consideration, but still no help.
How?
KFC said:
p0 = 0;
sigma_beta = 1;
plot(abs(phi).^2);
I don't see anything in there that involves N.
