General chain rule (mulitvariable calculus)
5 replies · 2K views
Langrange
question from early transcendentals (Edwards, penny) . chapter 12 partial differentiation
problem 38
1/R = 1/R1 + 1/R2 + 1/R3
R is resistance measured in Ω
R1 and R2 are 100Ω and increasing with 1Ω/s
R3 are 200Ω and decreasing with 2Ω/s
Is R increasing or decreasing at that instant ? at what rate ?
so what i have done is this
R(R,R,R) = (1/R1 + 1/R2 + 1/R3)-1
R1 = r1 + t
R2 = r2 + t
R3 = r3 - 2t
r is the initial values
using the chain rule
dR/dt = dR/dR1 * dR1/dt + dR/dR2 * dR2/dt + dR/dR3 * dR3/dt
i have probably misunderstood something important here . i get some answers but its not right, can someone explain to me how this works and where I am wrong.
the solution is supposed to be 0.24Ω/s
Hard to tell where you went wrong without seeing more details. Your work would be easier if you take the equation$$
R^{-1}= R_1^{-1}+R_2^{-1} + R_3^{-1}$$and differentiate that just as it stands implicitly with respect to t. Then put in the values.
problem 38
R1 = r1 + t
R2 = r2 + t
R3 = r3 - 2t
i have probably misunderstood something important here . i get some answers but its not right, can someone explain to me how this works and where I am wrong. the solution is supposed to be 0.24Ω/s
Let ##f(R) = \frac{1}{R}##
Now ##\frac{df(R)}{dt} = f'(R).\frac{dR}{dt}##
##f'(R)## is trivial
Now ##\frac{df(R)}{dt} = \frac{\partial f(R)}{\partial R_1}\frac{dR_1}{dt}+\frac{\partial f(R)}{\partial R_2}\frac{dR_2}{dt}+\frac{\partial f(R)}{\partial R_3}\frac{dR_3}{dt}##
Can you proceed from there?
BTW, assuming a linear relationship of the three resistances over time is invalid. All you know (or need to know) is that *at that instant*, the rates of change are as given. At another instant, they may be different, and all the resistances may behave in wildly nonlinear fashion.
but example f(R)/dR1
how do u do that one. doesn't that require even more substitutions.
because f(R)=1/R
because f(R)=1/R
Since I've defined ##f(R) = \frac{1}{R}## and since ##\frac{1}{R} = \frac{1}{R_1}+\frac{1}{R_2}+\frac{1}{R_3}##, you simply have ##f(R)=\frac{1}{R_1}+\frac{1}{R_2}+\frac{1}{R_3}##. You should be able to work out the partial derivatives very easily from that, and if you can't, I suggest a more thorough review of the topic.
