General Motion of a particle in 3 dimensions
The discussion focuses on the motion of mud particles thrown from a rolling wheel, specifically determining the maximum height they can achieve and the point of release on the wheel. The equation for maximum height is derived as b + v0² / 2g + gb² / 2v0², under the condition that v0² ≥ bg. Participants express confusion about the use of polar coordinates and the significance of the angle θ in the context of the problem. Clarifications are made regarding the direction of gravity and the initial height of the particles when they leave the wheel. Ultimately, the conversation leads to a better understanding of the particle's trajectory and the necessary calculations for determining its motion.
YauYauYau
Particles of mud are thrown from the rim of a rolling wheel. If the forward speed of the
wheel is v0, and the radius of the wheel is b, show that the greatest height above the ground that the mud can go is
b + v02 / 2g + gb2/ 2v02
At what point on the rolling wheel does this mud leave?
(Note: It is necessary to assume that v02≥bg.)
In 3 dimensions concept,
r = i b cosθ + j b sinθ
Since v = rω = rθ',
v = dr / dt = (-b sin θ i + b cos θ j) θ' = -v0 ( -sin θ i + cos θ j )
Firstly, find the time when the particle meets maximum height.
Take downwards as positive
for vertical direction,
v = u + at
0 = v0 cos θ + g t
Then I find the time with minus sign.
It sounds quite weird.
In case, how do I know which side of rim the particle is thrown from rolling wheel?
The forum has already posted that problem already but still I have no idea with it.
Thanks.
Not sure how you intend this equation. What is r here?
I think using this i and j notation is of no benefit. I would just consider a mud particle released at some point on the wheel (some theta) and find its vertical height and velocity.
I just try to transform it into polar coordinate by r = ix + my
Don't know whether it is correct or not
Since v = rω = rθ',
why is it 3 dimension? The particle and the wheel move in a plane. Why do you have the minus sign in front of v?
I think you mean r the position vector with respect to the centre of the wheel. So you treat the problem in the frame of reference of the wheel. And θ means the angle of r with respect to the positive horizontal axis. You also consider y positive upward. You should make the difference between a vector and its magnitude, denoting a vector by bold letter, for example.
So r = i b cosθ + j b sinθ. b=r here.
v = dr / dt = (-b sin θ i + b cos θ j) θ' = v0 ( -sin θ i + cos θ j )
v = u + at
0 = v0 cos θ + g t
If upward is positive you should take g with negative sign.
The particle does not start from zero height. Its height is b sinθ with respect to the centre of the wheel, when it leaves the wheel.
Thanks.
Find the maximum height at a given angle; then find the angle which corresponds to the maximum of the maximum height. :)
Yes, but what does r represent? A point on the rim? The position of a mud particle that has been thrown up? And where is the origin? Is it a fixed point on the ground?
Please, make it easier on everyone and consider a particle thrown from a point on the wheel at some angle theta around the wheel from, say, the top. What is its launch angle and speed?
Anyway thanks. I got the idea finally.
In the beginning, I misunderstand where the particle goes ( in case, now I know it is just assumed by me )
Then I realize how the coordinate comes.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
