General Physics Question -- Max height of a projectile
15 replies · 2K views
Jerret Spenst
When an object is thrown or propelled upwards and it meets the point at deceleration and drops; what is that point called, where the object is not moving in either direction?
Welcome to the PF.
"Point of inflection?"
Thank you! Now in that state, could you propose that there would be a new force acting on the object or even the loss of one.
Neglecting air resistance, there is only the force of gravity acting on the thrown object, and its acceleration (downwards) is constant.
True, but I'd like to discuss the possibility of theoretical forces not yet discovered or applied to general physics.
We don't allow speculation or theory development at the PF. We discuss mainstream science, as published in the peer-reviewed literature and mainstream textbooks.
:smile:
Not a problem! Thank you for the previous answer!
Why bother trying to introduce an extra force when the whole classical process can be calculated and predicted as accurately as you choose, using the existing classical forces - until you get to the scale of Relativity or QM.
PF protects itself (and you) from such whimsy.
If an object is propelled straight up from ground level, and is unaffected by wind or other forces, and it takes say, 4.6 seconds for it land back down, can it's max height be calculated? If so, what's the answer and math? Thanks!
Are you familiar with the Kinematic Equations of Motion for Constant Acceleration (gravity)?
Yes, but long time. Will brush up on it, and figure it out! Will be a good exercise. Thanks!
Oops, that Hyperphysics link takes you to the top level. Click on Mechanics in the upper left, and then on Velocity and Acceleration...
