General relationship for springs connected in series
The discussion revolves around determining the effective force constant of two springs connected in series and exploring the general relationship for multiple springs in such a configuration.
  • Participants discuss the relationship between the forces and extensions of the springs, questioning how to derive the effective spring constant from individual constants.
Participants are actively engaging with the problem, attempting to clarify the differences between force constants and effective constants, and exploring various equations to express the relationships involved. Some have provided guidance on deriving the effective spring constant, while others express confusion over the concepts presented.
There is some uncertainty regarding the application of equations and the definitions of force constants versus effective constants. Participants are also navigating through the implications of connecting springs in series and the resulting extensions.
Vandetah
What is the effective force constant of 2 springs which are connected in series? What is the general relationship for n springs connected in series?
im not sure if i should use
or is the formula for a series circuit also relevant?
Hi Vandetah! :smile:
When massless springs are connected in series, the forces exerted by each is the same. Can you derive a relation using this fact?
so if there's two springs then it would be
k1 = k2?
k1 = k2?
Not quite. Even though their forces are same, their extension will be different. For two strings, you have,
[tex]x_1 = \frac{F}{k_1}[/tex]
[tex]x_2 = \frac{F}{k_2}[/tex]
And, [itex]x= x_1 + x_2[/itex]
Do you see a relation between the spring constants now?
u might laugh at this but, does it mean that two constant springs connected to each other create a signle force constant and therefore act as if it were a single spring?
No, they produce a single force. Not the same force constant. That should be clear from the above equations :smile:
so that is the general relationship, but what about the effective force constant? Can i use the equation i mentioned in the op?
Noo...Use the equations I wrote in my earlier posts to derive the relation for the effective force constant!
is there a difference between just a force constant and an effective one?
Well, force constant is for a simple, single spring. The effective constant is the effective spring you replace a given setup with, so that you get the same force exerted by that single spring which the whole setup would exert.
so if i derive the equations u mentioned i will get
k1 = [itex]\frac{F}{x1}[/itex]
and
k2 = [itex]\frac{F}{x2}[/itex]
so k = k1+k2??
and
so k = k1+k2??
Noo :redface:
Use x = x1 + x2.
Infinitum said:
Noo :redface:
Use x = x1 + x2.
could it be?
x = [itex]\frac{F K_{2}+ F K_{1}}{K_{1}K_{2}}[/itex]
Vandetah said:
could it be?
Yes, but you need to find the effective constant, and not the final extension :wink:
Take x = F/k.
Imagine that you measure the extension of both springs applying the same force to each. You get ΔL1 with the first spring and ΔL2 with the other spring. If you connect the springs, the same force acts on each - you pull the second one with F, it stretches by ΔL2, the second spring pulls the first one with the same force, it extends by ΔL1, so the connected springs stretch by the sum ΔL1+ΔL2.
You put the connected springs in a black box to hide the point where they are connected. You say it is a spring inside and ask somebody to measure the spring constant, applying force F. The person measures the change of length ΔL, and calculates the spring constant k=F/ΔL. That is the effective spring constant of the device inside the black box.
You know that ΔL=ΔL1+ΔL2, and also that ΔL1=F/k1, ΔL2=F/k2, so you can express the effective spring constant with the individual ones.
ehild
lol that post above got me more confused :(
Ehild put all I was saying in one post.
Just use x=F/k in your last equation, where k is the effective constant. :smile:
1. Let 2 bodies connected with inextensible string.
If 1st body is pulled by a force and remained at rest, EQUAL force also exerted on 2nd object.
Thus spring#1 and spring#2 extended with equal force, x1 and x2
F=-k1x1=-k2x2 ...(1)
2. Total extension is x1+x2 due to F.
F=Keff(x1+x2)
Subt. (1) in (2)
-k2x2=-Keff((k2/k1)x2+x2)
k2=Keff((k2/k1)+1)
Keff =k1k2/k1+k2 like resistors in parallel
You mean that Keff=k1k2/k1+k2, that is Keff=2k2? It is wrong.
Or you just forgot the parentheses...
ehild
  • · Replies 56 ·
  • · Replies 17 ·
