Mentor
- 50,800
- 26,794
RiccardoVen said:PD and WBN, I've read many many times all this topic, expecially the last part on pebbles and so on, and I have to say I've learned more Physics from those few rows that from hundred of textbookpages.
Thanks for that.
You're welcome!
RiccardoVen said:1) the little ball is in free fall into a curved spacetime, due to Earth gravity. It's then in free float, experiencing no force on it, so its frame of reference is inertial. Its trajectory is then straight in spacetime being a geodesic in curve ST.
Ok so far except for one key point: the little ball's "frame of reference" is only inertial if we define it locally--that is, we have to pick some particular event on the ball's worldline and set up a local inertial frame centered on that event (i.e., that event is the origin of the frame, with t = x = y = z = 0), which can only cover a small piece of spacetime near that event--"near" in both space and time. In a curved spacetime, that's the best you can do; there is no way to set up a global inertial frame that covers all of spacetime.
RiccardoVen said:My first point is how the little ball would interpret "seeing" the observer accelerating towards it.
As an observer accelerating towards it. Within the local inertial frame, physics works the same as it does in flat spacetime; and in flat spacetime, the little ball would just be floating freely and the object would accelerate past it.
RiccardoVen said:My idea is the ball frame of reference must be kept local in order to avoid tidal forces, so it cannot encompass the observer lying thousand of meter below it
Well, yes, but the observer won't always be thousands of meters below. There will come a time when the little ball and the observer will be close enough together that the observer is within the local inertial frame of the little ball. Then things will work as I said above. If the observer is *not* close enough to be within the local inertial frame of the little ball, then of course you can't use that frame to describe the motion of the observer (for that portion of spacetime).
RiccardoVen said:the ST is curved here, so it's correct to say this wordline is vertical?
In a non-inertial frame in which the observer is at rest, yes. But of course this is a non-inertial frame, so it doesn't work the same as an inertial frame.
RiccardoVen said:"Looking" at the little ball, it would see it accelerating towards him. Since he can look around him, he can conclude he's on a gravity field on Earth ( and not in free-gravity space ) so is it correct to say he can say the little ball is experiencing just the gravity force as cause for its acceleration towards him?
Sure, but since he's using a non-inertial frame, this "gravity force" won't work like a "real" force; it is a "fictitious" force, like centrifugal force or coriolis force, that doesn't cause an object being influenced by it to feel any acceleration. A "real" force is always felt.
RiccardoVen said:how to properly depict the curved spacetime due to Earth gravity.
You can't depict all of the properties of curved spacetime in a single diagram. Which diagram you use depends on which properties you want to focus on.
RiccardoVen said:And better: how the little ball geodesic will look like into this "curved" ST?
It depends on which diagram you're using.
RiccardoVen said:Have I to use Swartzchild metric ofr that, i.e. using Penrose diagrams or so?
For some purposes these work fine. (Note, btw, that the Schwarzschild metric is not a spacetime diagram; it's part of the underlying math that can be depicted in various different ways by different diagrams. A Penrose diagram is one such diagram, but not the only possible one.)
RiccardoVen said:the problem really resemble me the known case of an observer ( little ball ) free falling into a black hole ( ok, no event horizon here, but we have a similar situation I think ).
Yes, these cases are similar for the portion of the black hole spacetime that is outside the horizon.
RiccardoVen said:how to draw both frame of reference, one inertial while the other not?
You can't draw them both on a single diagram.
RiccardoVen said:Probably I have to draw one of the 2 geodesic
There's only one geodesic, the worldline of the little ball. The worldline of the observer at rest on the Earth's surface is not a geodesic. The fact that it's vertical in a particular diagram using a non-inertial frame does not make it a geodesic; non-inertial frames don't work like inertial frames, and non-geodesic worldlines can appear straight in them.
RiccardoVen said:as an hyperbola in ST, since accelerated...
It won't necessarily be a hyperbola; that will depend on which diagram you use.
