General relativity question - geodesics.
6 replies · 2K views
ghetom
I'm doing some revision for a General relativity exam, and came across this question:
A Flat Earth space-time has co-ordinates (t, x, y, z), where z > 0, and a metric
ds2 = ((1 + gz)2)dt2 − dx2 − dy2 − dz2
where g is a positive constant.
Write down the geodesic equations in this space-time.
Hence, or otherwise, show that A Flat Earth physicist, stationary at a point with z = h, will measure a ‘gravitational acceleration’ of magnitude g(1 + gh)−1
I've solved the geodesics, but can't get the 'show that' at the end:
Using the Euler-Lagrange equation:
[tex]\stackrel{d}{ds} \stackrel{\partial L}{\partial \dot{x^{\mu}}} - \stackrel{\partial L}{\partial x^{\mu}} =0[/tex]
I get
[tex]\ddot{z} = 2g(1+gz)\dot{t}^2[/tex]
And
[tex]\dot{t} = E/(1+gz)^2[/tex] ( where E is a constant )
So
[tex]\ddot{z} = g{E^2}/(1+gz)^3[/tex]
which isn't right. Alternatively,
[tex]\ddot{z}= \dot{t}^2 z'' + \ddot{t}z'[/tex] ( where ' is (d/dt) )
it's stationary, so z' = 0 thus [tex]z''=\ddot{z}/\dot{t}^2=2g(1+gz)[/tex]
which still isn't right. Any takers?
I think the two in your geodesic equation shouldn't be there. You probably missed the 1/2 in the Christoffel symbol. Moreover you made a mistake in trying to find an expression for [itex](dt/ d\tau)^2[/itex]. Can you show us how you obtained your expression?
Yes the 2 is wrong. My apologies.
For the mu = 0 equation I have:
[tex](d/ds)(2\dot{t}(1+gz)^2) =0[/tex]
thus
[tex]\dot{t} (1+gz)^2 = constant[/tex]
also
[tex]\ddot{z} = \dot{t}d\dot{z}/dt = \dot{t}(d/dt)(\dot{t}z') = \dot{t}(z'(d\dot{t})/dt +\dot{t}z'')=\dot{t}^2z''+\ddot{t}z'[/tex]
Update: I've now solved it using the Christoffel symbols, but am still confused as to why the Euler-Lagrange method hasn't worked.This is wrong:
[tex]\ddot{z} = -g{\dot{t}^2}(1+gz)[/tex] (1)
It should read:
[tex]\ddot{z} =-g{\dot{t}^2}/(1+gz)[/tex] (2)
I got (1) direct from the EL equation
[tex]-2\ddot{z} - {\dot{t}^2}d_{z}(1+gz)^2 = 0[/tex] (3)
You're probably losing terms in places where you should be summing over the indices. Using the EL-equations I end up with [itex]\ddot{z}-g(1+gz)\dot{t}^2 =0[/itex].
Your second equation is wrong as well. Did you derive that one using the geodesic equation? Either way I just calculated it both ways and I get the same result, as it should be. I can't be of further assistance unless you show me your full derivation. Also I don't think you have gotten your [itex]\dot{t}[/itex] correct yet.
Thanks. Given that's the case then [tex]z''=\ddot{z}/\dot{t}^2=g(1+gz)[/tex] can't be true (since this is the wrong answer).
I can't see any thing wrong for [tex]\dot{t}[/tex]:
whats wrong with:
[tex]L = (1+gz)^2dt^2-dx^2-dy^2-dz^2)[/tex]
therefore by EL:
so
Your Lagrangian is wrong, recall [itex]L=g_{\alpha \beta}\dot{x}^\alpha\dot{x}^\beta=(1+gz)^2 \dot{t}^2-\dot{x}^2-\dot{y}^2-\dot{z}^2[/itex].
