- 9,571
- 2,690
Hopefully my rough math is good (only order of magnitude calculations are sensible, to me, for a scenario like this).
First, a general comment. If one requires and local inertial frame (LIF) in curved spacetime to have a flatness criteria which prevents build up of large effects over all of its dimensions, then the degree of flatness required (as a local measure) increases with increased LIF size. In particular, I find that doubling the LIF size doubles the required r coordinate for e.g. the center of the LIF. However, keeping the proper acceleration of a stationary observer the same when doubling r, requires quadrupling the the mass. But Schwarzschild radius is directly proportional to mass. So there must come a time when the scenario is no longer achievable, as you increase the LIF size (far any reasonably chosen flatness criterions) - because you will eventually be unable to have a stationary observer.
For the numbers I ran for this case, it doesn't work already with an, IMO, inadequate definition of flatness. What I picked, for simplicity, is simply that over the whole range of r (of rocket holding stationary world line) - million light years, to r + million light years, that change in proper acceleration of a stationary observer is no more than 1%. This is sort of ok from a spatial point of view, but not temporal. With this criteria, by the end of the process under discussion, the relative speed of the buoys will be large, due to how long this small acceleration difference will have acted. If one tightens the criteria a lot, it will be unachievable for the reason above.
So, I get that we need r of 400 million ly to achieve the modest flatness criterion, and then to have 1.5g proper acceleration of a stationary observer at this distance requires nearly 2*1028 solar masses. This will have a Schwarzschild radius of about 6*1015 ly. Which of course means, you are out of luck.
So, assuming there is a valid solution, it appears it is not just 'getting far enough from a big BH', it must be something else.
