- 9,577
- 2,693
Just a silly typo I corrected. I meant SC radius. As for the rest, M corresponds to some R (SC radius). For a chosen ratio of R and r (achieving an arbitrary escape velocity), r - R can be made as large as you want.PeterDonis said:Huh? The formula for escape velocity in Schwarzschild spacetime is ##\sqrt{2M / r}##, where ##r## is the Schwarzschild ##r##, i.e., the areal radius. There's no "SR radius" anywhere in there. The gamma factor corresponding to that escape velocity is ##1 / \sqrt{1 - 2M / r}##; you can easily calculate the value of ##r## for which that gamma factor is 1.6 million.
PeterDonis said:This is true (just adjust the mass of the gravitating body appropriately), but irrelevant to the problem. In the problem as given, we know the velocity of buoy #2 relative to the rocket (gamma factor 1.6 million), and we know buoy #2 does not escape (it comes to rest relative to the rocket a million light-years above it).
Perhaps you are confused by the fact that in the flat spacetime case, there is no such thing as "escape velocity". That's true, but again, it's irrelevant to the problem, because we are not using any concept of escape velocity in the flat case. We are only using it in the curved case. And in the curved case, the fact that buoy #2 does not escape is obvious: it comes to rest relative to the rocket! No object on a free-fall escape trajectory will do that. So in order to satisfy the EP, we must be able to find a patch of a curved spacetime that satisfies the flatness criterion over the required range, and has strong enough gravity to make buoy #2 come to rest relative to the rocket, despite its huge initial gamma factor of 1.6 million.
I have no idea why you would think that. The fact that buoy #2 does not escape is required for the scenario. See above.
But escape velocity per se, is not part of the problem, period. What is, that you ignore, is that #3, in free fall, achieve its peak altitude at the stationary observer, and the #2 is a million ly away at this time per #3 simultaneity.
