DaleSpam said:
it is very clear that the ECI is a local inertial reference frame (after all, the "I" in "ECI" is for "Inertial")
It might be "inertial" in the Newtonian sense, yes, but not in the GR sense. Which, of course, just underscores the ambiguity in terminology that has driven much of this thread.
PAllen said:
ECI stands for "earth centered inertial" frame, and as used with GR, it has a metric varying radially from the center, with connection coefficients becoming non-vanishing away from the center.
This means the ECI is
not a local inertial frame in the standard GR sense; such a frame would have vanishing connection coefficients everywhere within its domain. (The fact that the connection coefficients must vanish, to the accuracy of measurement, is what restricts the domain of a local inertial frame to a small patch of spacetime.) What you're describing, in GR terms, are more like Fermi normal coordinates centered on a freely falling worldline; such coordinates are not a local inertial frame because they can cover an entire "world tube" centered on the worldline, not just a small patch centered on a particular event. and the connection coefficients can become non-vanishing off the centered worldline because of spacetime curvature.
Also, as I understand it, the ECI frame, from a GR point of view, takes the metric for Fermi normal coordinates centered on a freely falling worldline, and adds in the Earth's gravitational potential "by hand" in the appropriate metric coefficients. (See, for example, the treatment in section 3 of the Living Reviews article on relativity in the GPS
http://relativity.livingreviews.org/Articles/lrr-2003-1/fulltext.html .) This means that, in GR terms, the ECI is not even an inertial frame in a small patch of spacetime; its metric is not Minkowski anywhere, because of the gravitational potential.
So the only sense in which the ECI could be said to be "inertial" is the Newtonian sense in which DaleSpam is using the term here. (The main intent of the "I" in ECI appears to be to signify that it is non-rotating, as opposed to the ECEF frame which rotates with the Earth. In GR terms, once again, this would mean Fermi normal coordinates, not local inertial coordinates--but then we still have the Earth's gravitational potential added in, as above.)
