Generalisations of area between two curves
  • Thread starter Gary Smart
    Area Curves
59 replies · 7K views · last reply
Gary Smart
The problem consists of investigating the area between two functions of the forms (Parabolic segment):
: y = mx + c and y = ax^2 + bx + c
The investigation involves finding a combination that has one of each of the above functions and finding an area of one. The area between the functions has to be in the first quarter (positive x and y).
2. The attempt at a solution
My investigation up to now has found the following:
Function 1: 6x^2 - 2x + 8
Function 2: 4x + 8
These give points of intersection of: (0,8) and (1,12). These are the lower and upper bounds when integrating.
Integration produces:
Curve: 3x^2 - x^2 + 8x [Boundaries of 0 and 1]: Area under curve = 9 (between 0 and 1).
Line: 2x^2 + 8x [Boundaries of 0 and 1]; Area under line = 10 (Between 0 and 1).
=> Area between line and curve is: 10 - 9 = 1
3. Further investigations
I have already found that the coefficient of A (Parabola) has to be a multiple of 3, otherwise there will be a recurring decimal when integrated.
My next steps involve:
: Producing any generalisations that affect finding this specific area with these two functions.
: Proving/generalising using Algebra.
There are a lot of things you haven't specified about this problem. May the parabola open either upwards or downwards? Must the intersections of the parabola and line be in the first quadrant? Is the area you want to calculate the area bounded by the two functions between the intersection points? Must the complete region "between" the functions lie in the first quadrant?
Also please show us how you got A must be a multiple of 3.
[Edit, added]: I would suggest starting with a simple subcase. For example, consider the two functions ##(x-a)^2## and ##mx##. See if you can show that for any ##a\ge 0## there is a corresponding ##m## that works. Get the relationship between ##m## and ##a##. Then start on more complicated cases.
The Parabola can open either upwards or downwards. The intersections of the parabola and the line must be in the first quarter. The area is bounded by the functions between the points and the complete region between the functions must lie in the first quadrant.
I got that A must be a multiple of 3 because when the quadratic is integrated, the A value is divided by 3. If the value of A isn't a multiple of 3 then the result will always give a recurring decimal and will never produce an area of one.
(x-a)^2 = x^2 − 2xa + a^2 is not a parabola though is it?
That is a parabolic function. The graph of ##y= (x-a)^2## is a parabola with vertex ##(a,0)## opening upwards. ##A## does not have to equal ##3##. Like I suggested, start with a real simple case. Take ##y=(x-1)^2## and ##y = mx##. It is obvious geometrically that there is some positive ##m## so that the area between the line and parabola is ##1##.
Hello LCKurtz,
I not hundred percent sure I understand the process here. I have tried different m values when y = (x-1)^2 and it produces an m of approximately 0.704 (3 dp). What is the aim of the investigation?
May you can use the absolute value of $$ \int_0^1f_1(x)dx-\int_0^1f_2(x) $$
The first function being the line and the second function being the parabola?
If you need just area, take absolute value. If you need sign then check for this on initial problem.
Just to check I understand what you are saying:
I only need the area: specifically an area of 1 and if there are any generalisations that can be made.
What is the absolute value?
Integral ##\int f\,dx ## comes from area calculation between function graph and x axis.
So, using that information.
The area of the function that is furthest away from the x-axis can't be less than 1?
The integral have sign from f(x). The geometrical area is positive defined, like as geometrical distance. For area take the positive answer.
This is because the area between the curves is above the x-axis and the fact there is no such thing as a negative geometrical distance?
Area is positive, integral may not. Distance is positive, position coordinate value may not.
I can't have negative integrals though? because the area is bounded in the first quadrant?
Your parabola is positive defined so every ##\int_a^bf_1(x)\,dx## must be positive. The other function may give negative integral on some limits.
Why must the parabola be positive? is that because we are subtracting the other function away from it, thus a negative subtracting a negative will always be a negative. Therefore will never give an area of 1?
Does the parabola have to be the first function? or can the line be function 1?
Both of these sets of functions are allowed in the constraints of this question.
  • Graph of a downward-opening parabola with its vertex near (4, 19), crossing the x-axis near x = 0 and x = 8, and a straight line with positive slope crossing it at two points.
  • Graph on a grid of two curves in red: a straight line with positive slope and a parabola opening upward, intersecting near the y-axis above y = 5 and below y = 10.
Function 2: 4x + 8
This problem represented by the second graph.
Function 2: 4x + 8
These functions give an area of 1 but the only reason I know why is when function 2's area is subtracted by function's 1 it gives an area of 1 (Parabolic segment). I don't know why else it works.
This is correct. See the axis units.
I know the x-axis units of intersection are 0 and 1. But using these units doesn't always work.
You make a coefficient error on your post, but I think this is typo, because you make the correct calculation
Curve: 3x^2 - x^2 + 8x [Boundaries of 0 and 1]: Area under curve = 9 (between 0 and 1). ---> 2x^3 ...
Okay, I get that. Is there a way of investigating this algebraically? Maybe proofing it e.g. if I wanted to find more areas of 1 in the first quadrant using a parabola and a line?
The trapezoidal rule will only give me the area the area under the line though?
So, I need to apply the trapezoidal rule in general to general forms of both types of functions?
No, trapezoidal rule is the discrete case (used on computational calculations) for the same think we make with calculus by integrals. Integrals are limits with ##\Delta{x}\to0## for the trapezoidal rule.
