Generic Intersection of non-planar Surfaces in R^4
The discussion centers on the intersection of two planar surfaces in R^4, emphasizing that they generically intersect at isolated points rather than along lines. The concept of transversality is crucial, as it dictates that if the intersection is transverse, the resulting intersection forms a submanifold with a dimension calculated by the formula (dim A + dim B - dim M). In this case, the dimension is zero, confirming that intersections occur at discrete points. The conversation also touches on the Poincaré dual of the intersection form in cohomology, highlighting its integer-valued nature.
  • Understanding of R^4 geometry
  • Familiarity with transversality in differential geometry
  • Knowledge of cohomology and Poincaré duality
  • Basic concepts of manifolds and submanifolds
  • Study the concept of transversality in differential topology
  • Explore Poincaré duality in algebraic topology
  • Investigate the properties of submanifolds in R^n
  • Learn about intersection theory in higher-dimensional spaces
Mathematicians, particularly those specializing in topology and geometry, as well as students and researchers interested in the intersection theory of manifolds in higher dimensions.
Bacle
Hi, everyone:
How do we show that 2 planar surfaces in R^4 intersect at points (possibly empty
sets of points, but not in lines, etc.).
I am curious to see how we justify the Poincare dual of the intersection form in
cohomology being modular, i.e., integer-valued.?
I am confused because the same does not seem to apply to, e.g., lines, which,
when embedded in R^2 or R^3 and R^4 , intersect (if at all) at points.
Thanks.
It's transversality. If the intersection is transverse, they intersect in a submanifold with the appropriate dimension (dim A +dim B - dim M). Here the dimension is 0, so they generically intersect in isolated points, if at all.
Just to say thanks, Zhentil; you have been very helpful.
  • · Replies 20 ·
