Geometrical interpretation of dot product?
4 replies · 7K views · last reply
excalibur313
Does anyone know what the geometrical interpretation of a dot product in 3-D is? I am calculating the dot product between two vectors in 3d and need to use the |a||b|cos(theta) interpretation basically, but that is for 2d. Can I just tack on an additional cos(theta2)? Thanks a lot for your help!
-Stephen
-Stephen
Nope... it's still |a||b|cos(theta) where theta is the (smaller) angle between the two vectors. If you have the rectangular components of the vectors, you can use
a_x b_x + a_y b_y + a_z b_z (which you might which to prove).
The usual geometrical interpretation of the dot-product is related to a projection of one vector onto the other.
Thanks a lot for your help, but I guess I am wondering what the best way to approach this problemis. The idea is that the resulting value of this dot product is based on the angle between them. (Where it will be a bigger value if they are lined up parallel) so it isn't really apparent to me how best to transform from cosine(theta) notation to cartesian coordinate system. Yeah, sorry I'm not trying to turn this into a homework help session, but basically I want to integrate over all possible angles so a cartesian coordinate system would be messy I think.
Okay, well the rate of fret is proportional to K^2 where:
K=3(p1.r)(p2.r)-(p1.p2)
Where p1 and p2 are the transition dipoles and r is a vector pointing from the center of p1 to the center of p2. r remains constant so I have to find <k^2> so I basically want to integrate over all orientations of the two transition dipoles. If this was in 2d I could just integrate over theta 1 and 2 because the angle between p1 and p2 is just the difference between those two. It looks like this: (p1) | ------> | (p2) where the arrow is r and the two vertical lines are the transition dipoles and can rotate. Anyway, thank you so much for anything you can do.
