Get PHP Coding Help for Beginners | Troubleshooting Tips
  • Thread starter Thread starter sean1234
    Coding Php
4 replies · 4K views
sean1234
I am just starting out with this and am having trouble getting the code to translate to a webpage. It is not really clear as to how this is to be done. I have created a basic program in notepad, saved it as .php and have attempted to open in IE but get a message that says something about not having the proper devices to run it.
Also I have attempted to run it through XAMPP, but have received errors about SQL syntax or something along those lines. I would appreciate any input on this matter.
I installed apache on my computer though I am still seeing these problems. Should I be able to run the program through IE with Apache?
You should drop the php file in your Apache site root and access it via IE as http://localhost/myphpfile.php
If the PHP file uses SQL you also need to have MySQL installed and configured.
Apache also needs to have PHP installed and you may have to add some stuff to the Apache config file so it knows to use PHP to interpret .php files.
