GF(3): Extending q(x) & Proving a is Not a Generator
  • Thread starter Thread starter andrey21
    Field
16 replies · 8K views
andrey21
Describe how the field GF(3) may be extended by postulating the existence of a root a of q(x) and list all the elements of this larger field. Show that a is not a generator of the extended field.
q(x) = x2+1
My attempt
First replace x with a we obtain:
0 = a2+1
a2=-1
a2=2 (-1=2 in mod 3 numbers)
Take powers up to a(3-1)=a2
a
a2 = 2
No I'm sure I have proven a is not a generator but I am unsue how to calculate the elements.
Hi andrey21, :smile:
The exact mathematical notation for the thing you're trying to descirbe is [tex]\mathbb{F}_3[X]/(X^2+1)[/tex]. Thus elements of this field are just polynomails in [tex]\mathbb{F}_3[/tex], but with the additional property that [tex]X^2+1=0[/tex]. This would also mean that [tex]X^3+X=0[/tex] for example.
Now, a general element in [tex]\mathbb{F}_3[X][/tex] is of the form [tex]a_nX^n+...a_1X+a_0[/tex]. Can you reduce this polynomial to a simpler form using the relation [tex]X^2=-1[/tex]?
a0+a1X+a2X2
Which can be written as:
a0+a1X+a2(-1)
a0+a1X-a2
So, if we have [tex]a_0+a_1X+a_2X^2[/tex], then we can always write it in the form [tex]a+bX[/tex] for a,b in GF(3).
Is the same possible for general polynomials [tex]a_0+a_1X+...+a_nX^n[/tex]?
Ok so the elements for GF(3) are in the form ax+b for 0,1,2:
Giving:
0x+0
0x+1
0x+2
1x+0
1x+1
1x+2
2x+0
2x+1
2x+2
correct?
Thank you micromass, so to conclude I can prove that a is not a generator as every element of GF(3) was not found when taking powers up to a2
That's not good enough. You've only calculated a and a2. Nothing says that a3, a4,... cannot give all elements of GF(3). It doesn't, but you need to calculate a3, a4,... first.
Ok so here's my revised answer:
a
a2=2
a3=2a
a4=2a2
=2(2)
=4
=1
Stop when get to 1, so every element is not found so a is not a generator.
Great Thank you micromass.
Hi micromass I have another similar question which I am having some problems with:
p(x) = x2+3
GF(5) (0,1,2,3,4)
I must find all elements and decide if a is a generator or not.
First elements are:
x
x+1
x+2
4x+4
correct??
Now rewriting P(x) replacing x with a:
0=a2+3
a2=-3
a2=2 (-3=2 in mod 5 numbers)
p(x) = x2+3
GF(5) (0,1,2,3,4)
First elements are:
x
x+1
x+2
4x+4
correct??
0=a2+3
a2=-3
That looks good already! So, now you need to calculate powers of a to see whether it is a generator...
so here's my answer:
a
a2=2
a3=2a
a4=2a2
=2(2)
=4
a5=4a
a6=4a2
=4(2)
=8
since 8 is not a element of GF(5) should I stop here since I have proved every element will not be obtained.
