Glass Transparency: What Allows Visible Light to Pass Through?
  • Context: High School
  • Thread starter Thread starter live4physics
    Glass
The transparency of glass to visible light is primarily due to its molecular structure, where electron transitions do not match the energy of visible light, allowing it to pass through unabsorbed. In contrast, substances like water can absorb infrared light, necessitating its removal in the production of fiber-optic glass. Photochromatic lenses utilize dye molecules that break down under UV light, creating loose electrons that can absorb visible light. The restoration of transparency in materials like lucite over time can occur through thermal annealing, demonstrating the dynamic nature of molecular structures.
  • Understanding of molecular structure and electron transitions
  • Knowledge of photochromatic materials and their chemical properties
  • Familiarity with Kramers-Kronig relations and dispersion theory
  • Basic principles of light absorption and transmission in materials
  • Research the molecular structure of glass and its impact on light transmission
  • Explore the chemistry of photochromatic dyes and their applications
  • Study Kramers-Kronig relations in the context of optical materials
  • Investigate the processes of thermal annealing in restoring transparency in materials
Materials scientists, optical engineers, and anyone interested in the properties of transparent materials and their applications in technology.
live4physics
What´s glass feature (molecular structure) that allow the visible light bypass it ?
:confused:
Thanks
Basically there is nothing to absorb the light.
The electron transitions in glass do not match the energy of visible light and so it goes straight through - the same mechanism that makes water transparent.
Other substances in the glass can change the absorption, water strongly absorbs infrared so to make glass fibre-optic for infrared you have to remove all the water from the molten glass first.
In the case of photochromatic lens, how the UV rays changes the molecular links between atoms ? are there any electron transitions ?
Thanks.
Thanks.
Photochromatic is a dye molecule that gets broken by UV light, this leaves a bunch of bonds with lots of loose electrons that can then change energy levels and absorb visible light.
The clever bit is finding a dye that heals itself when you take it out of UV.
I have a block of formerly transparent lucite that was irradiated with a 15 MeV electron beam in 1959. It was a dark brown due to F-center dislocation. Now, 50 years later, it is transparent again, due to thermal (room temperature) annealing.
For glass to be truly transparent (no absorption), there can be no dispersion (See Kramers Kronig or dispersion relations). See
http://en.wikipedia.org/wiki/Kramers-Kronig_relations
These also apply to the real and imajinary components of electrical circuits.
10K
  • · Replies 22 ·
