Going from cylindrical to cartesian coordinates
13 replies · 3K views
Niles
Hi
The expression for the magnetic field from an infinite wire is
[tex] \boldsymbol B(r) = \frac{\mu_0I}{2\pi}\frac{1}{r} \hat\phi[/tex]
which points along [itex]\phi[/itex]. I am trying to convert this into cartesian coordinates, and what I get is
[tex] \boldsymbol B(x, y) = \frac{\mu_0I}{2\pi}\frac{1}{\sqrt{x^2+y^2}} \hat\phi[/tex]
where
[tex] \hat\phi = -\sin\phi \hat x + \cos\phi \hat y[/tex]
I am trying to make a phase plot of this expression, so what I have done is to say that [itex]\phi = \arctan(y/x)[/itex], so [itex]\hat\phi = -\sin(\arctan(y/x))\hat x + \cos(\arctan(y/x))\hat y[/itex]. However I don't get the desired result. Have I missed something in my approach?
sin (arctan a) and cos (arctan a) can be simplified. Let z = arctan a, that means tan z = a, and tan z = sin z/cos z = a, so you can express sin z and cos z in terms of a.
Thanks, so I know that
[tex] \frac{y}{x} = \frac{\sin(\phi)}{\cos(\phi)}[/tex]
I can't see how this enables me to rewrite e.g. [itex]\sin(\arctan(y/x))[/itex].
## \sin (\arctan a) = \sin z ##. Since ##\tan z = \sin z/\cos z = a##, ##\sin^2 z = a^2 \cos^2 z = a^2(1 - \sin^2 z)##. So you can find ##\sin z## as a function of ##a##; ditto for ##\cos z##. Then substitute ## a = y/x ##.
Ah, I see. So I get
[tex] \sin z = \frac{a}{\sqrt{1+a^2}} \\<br /> \cos z = \frac{1}{\sqrt{1+a^2}}[/tex]
But I still have my original problem: That when I plot B using these for negative x, then I don't see the correct magnetic field. I thought that I was perhaps missing a term [itex]\pi/2[/itex], but that didn't solve it either.
I have attached a plot of what I see (the axes are (x, y), the current 1A and the units on the axis in meters), it is called "negative_x". If I only plot for positive x-values I get "positive_x", and there I see what I expect (as shown here, on the top: http://www.netdenizen.com/emagnet/solenoids/frommaxwellonly.htm).
My code in Mathematica for plotting is:
VectorPlot[(mu0/2 pi)*
current*(1/(x^2 + y^2)^(1/2))*{-(y/x)/(1 + y^2/x^2)^(1/2),
1/(1 + y^2/x^2)^(1/2)}, {x, -0.01, 0.01}, {y, -0.01, 0.01}]
You should be able to simply the formula very significantly. Note that ## \frac 1 {\sqrt {1 + y^2/x^2}} = \frac x {\sqrt {x^2 + y^2}} ##, and the radical in the denominator nicely couples with that in the common factor. But even then your formula is not wrong, I am not sure why Mathematica does not plot it correctly.
I don't know either. Strange, but nice to know that I have the correct exprssion. Thanks!
OK, I just plotted it in MatLAB, and it *isn't* correct. For x<0 the y-coordinates all have to change sign. So the expression is not correct.
EDIT: I have attached the plot.
Yes, it didn't change anything. It shouldn't either, since it is just a different way of expressing it.
Your formula is ## (\mu_0/2 \pi)
I \frac 1 {(x^2 + y^2)^{1/2}} \left(\frac {-y/x } {(1 + y^2/x^2)^{1/2}},
\frac 1 {(1 + y^2/x^2)^{1/2}} \right)##
Observe that the y-component is always positive, which is incorrect. If you transform it the way I suggested, you will get ## (\mu_0/2 \pi) I \frac 1 {x^2 + y^2} \left(-y, x\right)##, which restores the correct sign.
thanks! I must have made an error somewhere then when I tried
