What Is the Wavelength of the Signal Based on Goniometer Measurements?
The wavelength of the signal measured using goniometer measurements is determined by the distance moved through multiple intensity minima and maxima. Initially, the receiver is positioned at 8.4 cm, and after moving through 10 minima, it reaches 27.3 cm. The correct calculation for the wavelength (ƛ) is ƛ = (27.3 cm - 8.4 cm) / 5, resulting in a wavelength of 3.78 cm. This method accounts for the five complete wavelengths represented by the ten minima.
  • Understanding of wave properties and behavior
  • Familiarity with goniometer measurements
  • Knowledge of intensity maxima and minima in wave patterns
  • Basic algebra for solving equations
  • Study wave interference patterns and their implications in physics
  • Learn about the principles of goniometry in wave measurements
  • Explore the mathematical derivation of wavelength calculations
  • Investigate the applications of goniometers in experimental physics
Students in physics, particularly those studying wave mechanics, as well as educators and researchers involved in experimental setups using goniometers.
Mnemonic
Initially your receiver is positioned at a distance of 8.4 cm from the goniometer and recording a maximum intensity. You move it through 10 minimums in the intensity and then stop at the next maximum intensity. The receiver is now a distance of 27.3 cm from the goniometer.
What is the wavelength of the signal you have measured?
ƛ/2=Distance between two maximums
ƛ=2(27.3-8.4)cm
=37.8cm
It's that simple right?
I keep getting the wrong answer with this. What am I missing?
ƛ=2(27.3-8.4)cm
=37.8cm
You are not taking into account that it was moved through many minima and maxima. You have calculated as though it was moved to the very next maximum.
The wording in the question confused me. So you are saying that between each of the 10 minimums there was a maximum as well?
That's the usual arrangement.
SO there are 5 complete wavelengths.
Therefore ƛ=(27.3-8.4)/5 cm
That looks better.
  • · Replies 19 ·
