GR: "Proper Distance" Meaning and Usage
  • Context: Graduate
  • Thread starter Thread starter pervect
    Gr Proper distance
The discussion revolves around the term "proper distance" in General Relativity (GR), exploring its meanings, applications, and the terminology associated with measuring distances in curved spacetime. Participants examine different contexts in which "proper distance" is used, including cosmological scenarios and the implications of various definitions.
  • Some participants identify two meanings of "proper distance": one related to flat spacetime and the Lorentz interval, and another used synonymously with "comoving distance" in cosmology.
  • Others clarify that "proper distance" in cosmology refers to the spatial geodesic measured along a hypersurface of constant cosmic time, distinguishing it from "comoving distance."
  • A participant suggests substituting "displacement" for "distance" in certain contexts.
  • There is a discussion about integrating the metric line element along spacelike curves to define "proper distance," with some proposing that this could apply to any arbitrary spacelike curve.
  • One participant describes a method for defining proper distance based on congruences of timelike worldlines and spacelike curves, noting that definitions can vary depending on the observer's congruence.
  • Another participant mentions that proper distance can change over time, depending on the spacelike curves intersecting the congruence at different times.
  • There is a suggestion that the proper distance definition may differ from that using Fermi normal coordinates, which always involve spacelike geodesics.
  • Terminology for distances measured along spacelike geodesics is discussed, with references to various authors' definitions, including Wald's use of "length" for spacelike curves.
  • Some participants express skepticism about certain definitions, suggesting that they may be overly simplistic or not comprehensive enough.
Participants express differing views on the definitions and implications of "proper distance," with no consensus reached on a singular definition or usage. The discussion remains unresolved regarding the best terminology and the nuances of the concept.
Some definitions depend on the choice of congruence of observers, and the discussion highlights the potential for different interpretations based on the context of spacetime being considered.
  • #91
yuiop said:
Now if I set r0 = infinite in your equation, it reduces to:
[tex] \frac{dr}{dt} = \sqrt{\frac{2m}{r}(1-v_0^2) +2mv_0^2} [/tex]
which does not agree with either the mathpages coordinate velocity or proper velocity:
You might want to double check that.
I get:
[tex] \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }[/tex]
yuiop said:
The local velocity of a falling particle with initial velocity v0 at infinity, according to an observer at r, was derived in #79 and is:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v_0^2) +v_0^2} [/tex]
This formula is identical to mine if we take r0 = infinity.
This is identical:
[tex] \sqrt {{v_0}^{2}+{\frac {1-{v_0}^{2}}{r}}}=\sqrt {{r}^{-1}-{\frac {<br /> \left( -r+1 \right) {v_0}^{2}}{r}}}[/tex]
yuiop said:
[tex] \frac{dr single-quote}{dt single-quote} = \sqrt{\frac{2m(r^{-1} - r_0^{-1})}{(1-2m/r_0)}} [/tex]
It looks like you are right on that one.
  • #92
I get:
Starting with your equation:
[tex]\Rightarrow \sqrt {\frac{2m}{r}-\frac { 2m\left( -r+1 \right) <br /> v_0^2}{r}} [/tex]
[tex]\Rightarrow \sqrt {\frac{2m}{r} +2mv_0^2-\frac { 2mv_0^2}{r}} [/tex]
[tex]\Rightarrow \sqrt {\frac{2m}{r}(1-v_0^2) +2mv_0^2}[/tex]
So we both get the same result for the reduction of your equation when r0 = infinite, and this does not agree exactly with the equation I gave in #89:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v0^2) +v0^2} [/tex]
Do you now at least agree that the equations I gave in #89 are correct?
I note that sometimes you are explicitly using rs = 2m and other times using rs = 1 which might lead to errors.
Your generic equation is close for the r0 = infinity case if we only use rs =1 but it is miles out for the v0 = 0 and r0<infinite case.
  • #93
Ok, let's take a look at the formulas you presented.
When I enter m=1/2, v0=1/2 and r=1 I get a v>1 this does not seem right. In fact v reaches 1 already at r=4/3 using your formula. Unless I am mistaken v=1 should only happen at the EH. My formula gives v=1 at r=1.
yuiop said:
I note that sometimes you explicitly using rs = 2m and other times using rs = 1 which might lead to errors.
Yes, I apologize for that, I changed many formulas around to express them in terms of m instead of rs but some have not been updated.
  • #94
I am not sure how you get that result. I get:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v0^2) +v0^2} = \sqrt{\frac{1}{1}(1-(0.5)^2) +(0.5)^2} = \sqrt{1-0.25 + 0.25} = 1[/tex]
Try your formula:
[tex] <br /> \frac(dr'}{dt'} = \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }<br /> [/tex]
using m=7, r=2m and v0 =1/2 and you will see where the problem is. (My (mathpages) equation works for any arbitrary value of m.)
  • #95
Try your formula:
[tex] <br /> \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }<br /> [/tex]
using m=7, r=2m and v0 =1/2 and you will see where the problem is. (My equation works for any arbitrary value of m.)
Sorry yuiop I am definitely not having my day, must be my jet lag due to moving from China to the USA.
Ok, now I think your formulas look good, I am going to play with them a little. Would it be possible to get a generic "Fermi distance formula"? I am going to take your formulas to get a generic distance formula as well.
Ok, here are the plots for the formulas you presented, and they look good. One thing is very different, the 'dropped from a r value' observers. In my plot the distance decrease is definitely not linear while using your formulas it appears linear. But I think yours are correct and mine were wrong.
In the last graph the stationary observers are obviously not in motion so each point on the plot represents a different observer at a different r value.
  • #96
The paramaterized equations for a general spacelike geodesic will be given by the functions r(s) and t(s) that satisfy
[tex] \frac{dt}{ds} = \frac{C}{1-2m/r}[/tex]
[tex] \left(\frac{dr}{ds}\right)^2 = 1 + C^2 - 2m/r[/tex]
where C is an arbitrary constant. To get the fermi-normal distance associated with the worldline of some particular time-like observer, you'll have to choose the correct value of C so that your geodesic is orthogonal to the worldline of your time-like obsever at the point where they cross.
  • #97
Can anyone suggest me any book to start with general theory of relativity and cosmology?
  • #98
Can anyone describe me simplest way that what the general theory relativity acutually tell.
  • · Replies 38 ·
  • · Replies 30 ·
  • · Replies 25 ·
  • · Replies 27 ·
