Gradient version of divergence theorem?
4 replies · 8K views
Cygnus_A
So we all know the divergence/Gauss's theorem as
[itex]∫ (\vec∇ ⋅ \vec v) dV = ∫\vec v \cdot d\vec S[/itex]
Now I've come across something labeled as Gauss's theorem:
[itex]\int (\vec\nabla p)dV = \oint p d\vec S[/itex]
where p is a scalar function.
I was wondering if I could go about proving it in the following way (replacing dot products with implied sums):
With [itex]e_i := \hat e_i[/itex] and [itex]d\vec S := ds_1 \hat x + ds_2 \hat y + ds_3 \hat z = ds_i e_i[/itex],
[itex]\oint p d\vec S = \oint p (e_i ds_i) = \oint (p e_i)(ds_i) = \oint \vec p \cdot d\vec s[/itex] (this p vector has scalar functional dependence still, it's just [itex](p)(\vec v)[/itex], a scalar times a vector, but still overall a vector in my mind)
then applying divergence theorem and getting
[itex]= \int (\vec \nabla \cdot \vec p) dV = \int \partial_i (p e_i) dV[/itex]
and finally applying the product rule and the fact that [itex]e_i[/itex] is a unit vector
[itex]\int (e_i \partial_i p + p \partial_i e_i) dV[/itex].
The second term is zero, since it's a partial of a unit vector, which has no spatial dependence, leaving
[itex]\int (e_i \partial_i p)dV = \int (\vec \nabla p) dV[/itex]
Does that make sense? I think it seems to work out, but I'm concerned that it's flawed due to my free conversions between sums and vectors. It seems unnatural that I've said [itex]d\vec S =d\vec s = ds_i[/itex], despite defining them differently. One, I suppose has actual vector components, whereas the other is just a list of components.
I believe the gradient version of the divergence theorem would be your typical statement that the integral of the path going through a potential is just the difference in potentials.
You must be thinking of the fundamental theorem of calculus for gradients -- [itex]\phi (\vec b) - \phi (\vec a) = \int_a^b \vec \nabla \phi \cdot d\vec r[/itex]
This was what was presented to me during a proof, and I had never seen it before
[itex]\int (\vec\nabla p)dV = \oint p d\vec S[/itex](oops, and I just realized I forgot to close the surface integral of divergence theorem in my original post :P)
The usual proof of the scalar version of the divergence theorem involves replacing the vector field v by (p k), where p is a scalar field and k is an arbitrary constant vector. Then div v is equal to k.grad p. Since k is arbitrary it can then be removed from both sides giving the result.
Ah, ok. The steps are essentially the same then. Just slightly different in how you get your constant vector. Thanks!
