Graphing a cubed root function
27 replies · 4K views · last reply
frosty8688
Sketch the curve of [itex]\sqrt[3]{(x^{2} - 1)^{2}}[/itex][/b]
I determined that the domain is all real numbers, the x-int. is ±1, the y-int. is 1, the function is symmetric about the y-axis, there are no asymptotes, and here is where I get lost. I took the first derivative of the function and found it to be equal to[itex]\frac{2}{3}[/itex] (x[itex]^{2}[/itex] - 1)[itex]^{\frac{-1}{3}}[/itex] * 2x = [itex]\frac{4x}{3\sqrt[3]{x^{2}-1}}[/itex] I know one of the critical numbers is 0 and I am wondering if the other numbers is ±1.
frosty8688 said:
1. Sketch the curve of [itex]\sqrt[3]{(x^{2} - 1)^{2}}[/itex]
3. I determined that the domain is all real numbers, the x-int. is ±1, the y-int. is 1, the function is symmetric about the y-axis, there are no asymptotes, and here is where I get lost. I took the first derivative of the function and found it to be equal to[itex]\frac{2}{3}[/itex] (x[itex]^{2}[/itex] - 1)[itex]^{\frac{-1}{3}}[/itex] * 2x = [itex]\frac{4x}{3\sqrt[3]{x^{2}-1}}[/itex] I know one of the critical numbers is 0 and I am wondering if the other numbers is ±1
What do you mean on "the x-int. is ±1, the y-int. is 1"?
Where is the function increasing and where is it decreasing? Try to sketch it. What happens at x=±1?
ehild
At x=±1 the function lands on the x-axis. The function is decreasing on (-∞,0) and increasing on (0,∞).
What happens in the interval (-1,1)?
ehild
frosty8688 said:
I know one of the critical numbers is 0 and I am wondering if the other numbers is ±1 [/b]
Since the derivative is undefined at x = ±1, those also are critical numbers.
frosty8688 said:
It concaves downward.
What is the function at x=0?
Is it increasing or decreasing between -1 and 0, and between 0 and 1?
ehild
It is increasing between -1 and 0 and decreasing between 0 and 1.
Well, so it is decreasing in (-∞,-1), increasing between -1 and 0, decreasing between 0 and 1, increasing in (1,∞). The function is 1 at x=0 and 0 at ±1. Can you sketch it?
ehild
I have another question. I am trying to find the second derivative of the function and this is what I have. [itex]f"(x) = \frac{4*3\sqrt[3]{x^{2}- 1}- 4x*3*\frac{1}{3\sqrt[3]{x^{2}-1}}}{9\sqrt[3]{(x^{2}-1)}^{2}} = \frac{12\sqrt[3]{x^{2}-1}- 12x}{27\sqrt[3]{(x^{2}-1)^{2}}\sqrt[3]{x^{2}-1}} = \frac{12\sqrt[3]{x^{2}-1}- 12x}{27(x^{2}-1)}[/itex]. I am wondering if this is right so far.
Incorrect.
The derivative of [itex]\ \ 3\sqrt[3]{x^2-1}\ \[/itex] is [itex]\displaystyle \ \ \frac{2x}{\sqrt[3]{(x^2-1)^2}}\ .[/itex]
frosty8688 said:
I'm talking about the second derivative.
So was I.
In taking the derivative, using the quotient rule, you took the derivative of the denominator of the first derivative incorrectly.
So the equation becomes [itex]f"(x) = \frac{4*3\sqrt[3]{x^{2}-1}- 4x*\frac{2x}{\sqrt[3]{(x^{2}-1)^{2}}}}{9\sqrt[3]{(x^{2}-1)^{2}}} = \frac{12\sqrt[3]{x^{2}-1}- 8x^{2}}{9(x^{2}-1)\sqrt[3]{x^{2}-1}} = \frac{12-8x^{2}}{9(x^{2}-1)}[/itex]
Not quite.
The first step is correct.
[itex]\displaystyle f"(x) <br /> = \frac{4*3\sqrt[3]{x^{2}-1}- 4x*\frac{2x}{\sqrt[3]{(x^{2}-1)^{2}}}}{9\sqrt[3]{(x^{2}-1)^{2}}} <br /> = \frac{12\sqrt[3]{(x^{2}-1)^3}- 8x^{2}}{9(x^{2}-1)\sqrt[3]{x^{2}-1}}= \ \ \dots[/itex]
Is there a problem between the second and third steps.
So the cube root on the top would disappear and it would be [itex]\frac{4x^{2}-1}{9(x^{2}-1)\sqrt[3]{x^{2}-1}}[/itex]
When the cube root in the numerator disappears, the numerator becomes [itex]12(x^2-1)-8x^2\ .[/itex]
You simplified that incorrectly.
So the equation [itex]\frac{4(x^{2}-3)}{9(x^{2}-1)\sqrt[3]{x^{2}-1}}[/itex] has critical numbers at ±[itex]\sqrt{3}[/itex] or ±1.
It's not clear what equation you're referring to.
The first derivative is undefined at x = ±1 . Of course this means that the second derivative is also undefined at x = ±1 .
The second derivative is zero at [itex]x=\pm\sqrt{3}[/itex], so that the function has inflection points there.
frosty8688 said:
That is also where it concaves down. Right?
That's where it changes concavity, from up to down, or vice versa .
