Grassmann numbers and Fermions
This discussion clarifies the relationship between fermions and Grassmann numbers in Quantum Field Theory (QFT). While Grassmann numbers, such as ##\theta_1## and ##\theta_2##, yield zero when multiplied in certain combinations, the term ##\bar{\psi}(x)\psi(x)\bar{\psi}(x)\psi(x)## in the Quantum Electrodynamics (QED) Lagrangian does not automatically equate to zero. This is due to the fact that fermions are quantum particles governed by Fermi-Dirac statistics, and their creation and annihilation operators belong to a Clifford Algebra rather than solely a Grassmann algebra. The discussion emphasizes the importance of explicitly writing out terms in spinor components to understand their behavior.
  • Understanding of Quantum Field Theory (QFT)
  • Familiarity with Grassmann algebra
  • Knowledge of Fermi-Dirac statistics
  • Basic concepts of Clifford Algebra
  • Study the properties of Grassmann numbers in Quantum Field Theory
  • Learn how to derive terms in the QED Lagrangian explicitly using spinor components
  • Explore the structure and applications of Clifford Algebra in quantum mechanics
  • Investigate the implications of Fermi-Dirac statistics on particle behavior
Physicists, particularly those specializing in Quantum Field Theory, theoretical physicists, and students seeking to deepen their understanding of fermions and their mathematical representations.
kelly0303
Hello! I am a bit confused about fermions in QFT when they are considered grassmann numbers. If you have 2 grassmann numbers ##\theta_1## and ##\theta_2##, something of the form ##\theta_1\theta_2\theta_1\theta_2## gives zero. However, a term in a QED lagrangian of the form ##\bar{\psi(x)}\psi(x)\bar{\psi(x)}\psi(x)## is not automatically zero. If fermions are Grassmann numbers, why isn't that term also zero?
Fermions are not Grassmann numbers. Fermions are quantum particles with Fermi-Dirac statistics.
That statistics can be expressed by the fact that their creation operators are elements of a Grassmann algebra, and dually their annihilation operators are also elements of a (dual) Grassmann algebra. But the full algebra of Fermi-Dirac creation and annihilation operators forms a neutral signature Clifford Algebra.
Specifically:
\bar{\psi}_a(x)\psi_b(y) +\psi_b(y)\bar{\psi}_a(x) = \delta_{ab} \delta(y-x)\boldsymbol{1}
(That's the Kronecker and Dirac delta functions on the r.h.s.)
Well, how do you do derive that ##\theta_1\theta_2\theta_1\theta_2## gives zero? I guess you write ##\theta_1\theta_2\theta_1\theta_2 = - \theta_1\theta_1\theta_2\theta_2 = -0 \times 0 = 0##.
So the question is: if you write out the term ##\bar{\psi}(x)\psi(x)\bar{\psi}(x)\psi(x)## explicitly in spinorcomponents of ##\psi##, what do you get? I leave that explicit writing out to you; that's the essential part of your question, I think ;) So pick a basis and write it out.
edit: your tex-code should read \bar{\psi}(x) instead of \bar{\psi(x)} for readability if you ever want to use that in your own texts.
  • · Replies 49 ·
  • · Replies 20 ·
  • · Replies 38 ·
