Gravatational Field Strength problem (Grade 12 physics)
7 replies · 7K views
axxon
The gravitational field strength of an unknown planet is 15.5 N/kg on its surface. Calculate the value of “g” if the planets mass and radius were both doubled. Hint: Use variation.
g= GM /R2
Well my teacher gave a hint saying use variation so this was my attempt at it:
M / 2M = R2 / 2R2
Now this is where i kind of get stuck. If I simplify M, i am left with:
1/2 = R2 / 2R2
I don't now what i should do next or if i am even on the right track...
Thanks in advanced!
g= GM /R2
M / 2M = R2 / 2R2
Are you sure that this is correct? If you double R, how much does R2 change by?
it would be 4R wouldn't it?
Indeed it would. So now you have a simple ratio question. Doubling the radius divides g by 4, doubling the mass doubles g, so the overall effect on g is ...?
But how does doubling the radius dividing g by four and same with mass?
I can see that it would be 1/2 of g or g under these conditions would be 15.5 (1/2) = 7.75 N/kg
Okay, let's take it step by step.
You are given that the acceleration due to gravity on the surface of a planet with radius r=r0 and mass m = m0 is g=15.5 N/kg. In other words, you know that
[tex]15.5 = \frac{Gm_0}{r_0^2}[/tex]
Now, you are asked to determine the value of g if the radius of the planet was r=2r0 and it's mass was m=2m0. That is if both the radius and the mass are doubled. So using Newton's law of gravitation,
[tex]\begin{aligned}<br /> g & = \frac{G\left(2m_0\right)}{\left(2r_0\right)^2}\\<br /> & = \frac{2}{4}\underbrace{\frac{G m_0}{r_0^2}}_{15.5}\\<br /> & = \frac{1}{2}15.5\\<br /> g & = 7.25 \;N/kg<br /> \end{aligned}[/tex]
Do you follow?
Correct!
You might to recheck the final bit :wink:
OHH! That makes it muchh more clear! Thanks a bunch!
