billj
- 1
- 0
What happens to the neutrons in a neutron star as it collapses Into a black hole?
Same thing as happens to ALL matter that gets into a black hole, it disappears into the singularity. Now this is not believed to be physical but it's what the current model shows. Expectations are that if/when loop quantum gravity becomes a solid theory we might understand what's REALLY happening, but for now we don't.billj said:What happens to the neutrons in a neutron star as it collapses Into a black hole?
sevenperforce said:If the pressure at the center of a neutron star were to exceed the limits of neutron degeneracy pressure, then the neutrons would presumably start to collapse into a black hole.
What makes you think so?Bernie G said:That would only be true if the collapsed neutrons had a volume that approached zero.
Not necessarily. The density at the center of a neutron star is believed to exceed that of an atomic nucleus: 8e17 kg/m3. Of course, such high gravity is going to warp space pretty significantly, so Euclidean geometry doesn't exactly hold here...but taking the Euclidean approximation, a core which grows to 4.8 solar masses at this density will become a black hole in its own right without needing to collapse at all. If quark-degenerate matter starts to form at the core of a neutron star as neutrons begin to break down, then the density is expected to be around 1.7e18 kg/m3; such a quark-matter core would satisfy the condition for a black hole with just under 3.5 solar masses. A non-Euclidean formation would likely decrease these requirements significantly.Bernie G said:Let me rephrase the statement:
That would only be true if the collapsed neutrons had significantly less volume.
Jonathan Scott said:On the other hand, if they collapse to a form which is not sufficiently dense to cause an immediate black hole, then what happens beyond that would depend on the nature of that form and in particular the pressure it could support, but that form would also be certain to collapse to a black hole at a smaller mass than if it were able to remain as a neutron star because it would have greater density.
Indeed.Bernie G said:So far there are about 2000 observed neutron stars all with a maximum mass limit of about 2M☉. If neutron stars collapsed directly into black holes there should be black holes starting at 2M☉ but none have been observed yet. To me it looks like there is some kind of process intrinsic to neutron stars that limits their mass to about 2M☉.
In the case you quote, the energy comes from the collider.Bernie G said:Collider experiments show that when a nucleus collapses what is produced is from 1% quark type matter and 99% energy to 10% quark type matter and 90% energy.
So the binding energy between the quarks in quark-degenerate matter or a quark-gluon plasma is exactly identical to the binding energy between the quarks in a neutron? That doesn't quite make sense; breaking a bunch of neutrons down into quark-degenerate matter ought to release at least some of the strong-interaction-binding energy that kept the quarks in a baryonic configuration. Baryon number wouldn't be violated because you still have the same number of quarks, right?Jonathan Scott said:As far as I know, unless baryon number can be violated (which would be a non-mainstream assumption outside the scope of these forums), the effective rest energy (including internal kinetic energy) of the components of a neutron cannot be less than that of a proton, and quarks cannot be isolated, so very little additional kinetic energy can be obtained by breaking down a neutron into its components.
Jonathan Scott said:... so very little additional kinetic energy can be obtained by breaking down a neutron into its components.
This appears to be a personal theory of yours which you have already posted in some other threads, and I pointed out that you should start a new thread and provide acceptable references if you wished to continue to discuss it.Bernie G said:What if that new form was ultra relativistic quark matter? Ultra relativistic matter would either heat or escape the star.
sevenperforce said:So the binding energy between the quarks in quark-degenerate matter or a quark-gluon plasma is exactly identical to the binding energy between the quarks in a neutron? That doesn't quite make sense; breaking a bunch of neutrons down into quark-degenerate matter ought to release at least some of the strong-interaction-binding energy that kept the quarks in a baryonic configuration. Baryon number wouldn't be violated because you still have the same number of quarks, right?
Bernie G said:So are you saying when a 1000 MeV neutron disintegrates all we get out of it is some quarks with about 10 MeV rest mass?
Forgive me if this is an elementary or obvious question, but why can't quarks released by the collapsing neutrons be bound in quark-degenerate or strange matter? Would that violate baryon conservation, or would that somehow constitute "quark isolation" and thus be prevented?Jonathan Scott said:Baryon conservation and the fact that quarks can't be isolated together mean that per original neutron the internal kinetic energy of the bound systems of quarks plus the rest mass of any components with rest mass cannot add up to less than the mass of a proton.
sevenperforce said:Forgive me if this is an elementary or obvious question, but why can't quarks released by the collapsing neutrons be bound in quark-degenerate or strange matter? Would that violate baryon conservation, or would that somehow constitute "quark isolation" and thus be prevented?
Naturally.Jonathan Scott said:I don't see any reason why alternative forms should be prevented. Baryon number conservation doesn't prevent the quarks being arranged in other ways or being excited to other levels such as strange quarks (with the same baryon number). However, any bound group of quarks and gluons could only be isolated if the total baryon number is a whole number (which implies groups of three plus optional particle / antiparticle pairs).
sevenperforce said:Naturally.
So what, then, is to prevent a gravitationally-bound collection of neutrons from collapsing into a soup of strong-interaction-bound quark matter with matching baryon number but lower binding energy, for a net exothermic process? I'm assuming that 21 quarks bound together in quark-degenerate plasma is going to have a lower binding energy than 7 neutrons...
I guess it would only be possible if strangelets were stable.Jonathan Scott said:If that was possible and you took that 21-quark unit out of that environment without adding energy, it couldn't decay back to protons and neutrons without adding energy, so either it or some decay product would be stable but have a mass less than the corresponding number of protons. I don't find that plausible.
Jonathan Scott said:As most of the energy per particle is simply derived from gravity, the only way for anything other than electromagnetic radiation and neutrinos to escape from the surface is if there is some effect such as a significant fusion explosion of accumulated matter which generates a huge amount of energy over a very short time. That could then result in a flash of neutron star surface material being ejected into space, as a cloud or shell containing traces of elements such as iron.
Continuous or frequent fusion would not produce enough energy per particle, but if material builds up for a while before a fusion chain reaction, then the resulting shock wave might well propel a small amount of material to escape velocity.Bernie G said:Fusion reactions do not produce enough velocity for nuclei to escape a neutron star's surface.
sevenperforce said:If the pressure at the center of a neutron star were to exceed the limits of neutron degeneracy pressure, then the neutrons would presumably start to collapse into a black hole. If this black hole were small enough (e.g., on the order of a few thousand tonnes), then the radiation pressure from Hawking radiation could potentially be high enough to arrest further collapse.
sevenperforce said:such high gravity is going to warp space pretty significantly, so Euclidean geometry doesn't exactly hold here
