billj
- 1
- 0
What happens to the neutrons in a neutron star as it collapses Into a black hole?
Same thing as happens to ALL matter that gets into a black hole, it disappears into the singularity. Now this is not believed to be physical but it's what the current model shows. Expectations are that if/when loop quantum gravity becomes a solid theory we might understand what's REALLY happening, but for now we don't.billj said:What happens to the neutrons in a neutron star as it collapses Into a black hole?
Bernie G said:If some neutrons collapse in a neutron star do all neutrons collapse?
sevenperforce said:If the pressure at the center of a neutron star were to exceed the limits of neutron degeneracy pressure, then the neutrons would presumably start to collapse into a black hole.
What makes you think so?Bernie G said:That would only be true if the collapsed neutrons had a volume that approached zero.
Not necessarily. The density at the center of a neutron star is believed to exceed that of an atomic nucleus: 8e17 kg/m3. Of course, such high gravity is going to warp space pretty significantly, so Euclidean geometry doesn't exactly hold here...but taking the Euclidean approximation, a core which grows to 4.8 solar masses at this density will become a black hole in its own right without needing to collapse at all. If quark-degenerate matter starts to form at the core of a neutron star as neutrons begin to break down, then the density is expected to be around 1.7e18 kg/m3; such a quark-matter core would satisfy the condition for a black hole with just under 3.5 solar masses. A non-Euclidean formation would likely decrease these requirements significantly.Bernie G said:Let me rephrase the statement:
That would only be true if the collapsed neutrons had significantly less volume.
Jonathan Scott said:On the other hand, if they collapse to a form which is not sufficiently dense to cause an immediate black hole, then what happens beyond that would depend on the nature of that form and in particular the pressure it could support, but that form would also be certain to collapse to a black hole at a smaller mass than if it were able to remain as a neutron star because it would have greater density.
Indeed.Bernie G said:So far there are about 2000 observed neutron stars all with a maximum mass limit of about 2M☉. If neutron stars collapsed directly into black holes there should be black holes starting at 2M☉ but none have been observed yet. To me it looks like there is some kind of process intrinsic to neutron stars that limits their mass to about 2M☉.
In the case you quote, the energy comes from the collider.Bernie G said:Collider experiments show that when a nucleus collapses what is produced is from 1% quark type matter and 99% energy to 10% quark type matter and 90% energy.
So the binding energy between the quarks in quark-degenerate matter or a quark-gluon plasma is exactly identical to the binding energy between the quarks in a neutron? That doesn't quite make sense; breaking a bunch of neutrons down into quark-degenerate matter ought to release at least some of the strong-interaction-binding energy that kept the quarks in a baryonic configuration. Baryon number wouldn't be violated because you still have the same number of quarks, right?Jonathan Scott said:As far as I know, unless baryon number can be violated (which would be a non-mainstream assumption outside the scope of these forums), the effective rest energy (including internal kinetic energy) of the components of a neutron cannot be less than that of a proton, and quarks cannot be isolated, so very little additional kinetic energy can be obtained by breaking down a neutron into its components.
Jonathan Scott said:... so very little additional kinetic energy can be obtained by breaking down a neutron into its components.
This appears to be a personal theory of yours which you have already posted in some other threads, and I pointed out that you should start a new thread and provide acceptable references if you wished to continue to discuss it.Bernie G said:What if that new form was ultra relativistic quark matter? Ultra relativistic matter would either heat or escape the star.
sevenperforce said:So the binding energy between the quarks in quark-degenerate matter or a quark-gluon plasma is exactly identical to the binding energy between the quarks in a neutron? That doesn't quite make sense; breaking a bunch of neutrons down into quark-degenerate matter ought to release at least some of the strong-interaction-binding energy that kept the quarks in a baryonic configuration. Baryon number wouldn't be violated because you still have the same number of quarks, right?
Bernie G said:So are you saying when a 1000 MeV neutron disintegrates all we get out of it is some quarks with about 10 MeV rest mass?
Forgive me if this is an elementary or obvious question, but why can't quarks released by the collapsing neutrons be bound in quark-degenerate or strange matter? Would that violate baryon conservation, or would that somehow constitute "quark isolation" and thus be prevented?Jonathan Scott said:Baryon conservation and the fact that quarks can't be isolated together mean that per original neutron the internal kinetic energy of the bound systems of quarks plus the rest mass of any components with rest mass cannot add up to less than the mass of a proton.
sevenperforce said:Forgive me if this is an elementary or obvious question, but why can't quarks released by the collapsing neutrons be bound in quark-degenerate or strange matter? Would that violate baryon conservation, or would that somehow constitute "quark isolation" and thus be prevented?
Naturally.Jonathan Scott said:I don't see any reason why alternative forms should be prevented. Baryon number conservation doesn't prevent the quarks being arranged in other ways or being excited to other levels such as strange quarks (with the same baryon number). However, any bound group of quarks and gluons could only be isolated if the total baryon number is a whole number (which implies groups of three plus optional particle / antiparticle pairs).
sevenperforce said:Naturally.
So what, then, is to prevent a gravitationally-bound collection of neutrons from collapsing into a soup of strong-interaction-bound quark matter with matching baryon number but lower binding energy, for a net exothermic process? I'm assuming that 21 quarks bound together in quark-degenerate plasma is going to have a lower binding energy than 7 neutrons...
I guess it would only be possible if strangelets were stable.Jonathan Scott said:If that was possible and you took that 21-quark unit out of that environment without adding energy, it couldn't decay back to protons and neutrons without adding energy, so either it or some decay product would be stable but have a mass less than the corresponding number of protons. I don't find that plausible.
Jonathan Scott said:As most of the energy per particle is simply derived from gravity, the only way for anything other than electromagnetic radiation and neutrinos to escape from the surface is if there is some effect such as a significant fusion explosion of accumulated matter which generates a huge amount of energy over a very short time. That could then result in a flash of neutron star surface material being ejected into space, as a cloud or shell containing traces of elements such as iron.
Continuous or frequent fusion would not produce enough energy per particle, but if material builds up for a while before a fusion chain reaction, then the resulting shock wave might well propel a small amount of material to escape velocity.Bernie G said:Fusion reactions do not produce enough velocity for nuclei to escape a neutron star's surface.
sevenperforce said:If the pressure at the center of a neutron star were to exceed the limits of neutron degeneracy pressure, then the neutrons would presumably start to collapse into a black hole. If this black hole were small enough (e.g., on the order of a few thousand tonnes), then the radiation pressure from Hawking radiation could potentially be high enough to arrest further collapse.
sevenperforce said:such high gravity is going to warp space pretty significantly, so Euclidean geometry doesn't exactly hold here
sevenperforce said:breaking a bunch of neutrons down into quark-degenerate matter ought to release at least some of the strong-interaction-binding energy that kept the quarks in a baryonic configuration
sevenperforce said:why can't quarks released by the collapsing neutrons be bound in quark-degenerate or strange matter?
sevenperforce said:I'm assuming that 21 quarks bound together in quark-degenerate plasma is going to have a lower binding energy than 7 neutrons
Bernie G said:Maybe core neutrons collapse into 1% quark matter with 99% energy that result in super intense X-rays which could result in intense positron/electron production.
Sounds good to me.PeterDonis said:It might be helpful to take a step back and look at the starting premise of this thread:
We have to find a plausible scenario for a neutron star collapsing into a black hole. One such scenario would be a neutron star that is below the maximum mass limit, but not by much, accreting enough mass onto it to push it over the limit (for example, the neutron star could be in a binary system with a massive companion and material from the companion could fall onto the neutron star). If that scenario seems ok to everyone, then further discussion can be based on it.
Ah. Quark-degenerate matter is a higher-energy state than baryonic matter. Got it!PeterDonis said:This reasoning would be valid if quark-degenerate matter were a possible state of matter at zero temperature, as baryonic configurations are. But it isn't; it can only exist to begin with at very high temperatures. Which means that the transition from baryonic configurations to quark-degenerate matter requires an input of energy; it is not a transition that will release energy, whether it's "binding energy" or anything else.
Well, in this case, we'd obviously have a collapse happening, so it's definitely not a static system.PeterDonis said:No, this won't work. It is true that, if we look at the event horizon in a spacetime where an object like a neutron star (or an ordinary star) is collapsing to a black hole, the horizon forms at the center, ##r = 0##, and moves outward until it reaches the Schwarzschild radius associated with the total mass of the object. But that does not mean the mass of the black hole starts at zero and slowly grows; what it means is that, until all of the matter in the object has collapsed below the event horizon, there is no clean way to separate the "black hole" from "the rest of the object".
What's more, you can't even have a static system with a radius just a little bit larger than the Schwarzschild radius associated with its mass. There is a theorem called Buchdahl's theorem which says that the minimum radius that any static system can have is 9/8 of the Schwarzschild radius associated with its mass. That means there is a finite "gap" between an object being stable in a static configuration and an object being a black hole; there is no continuous sequence of static configurations with gradually increasing mass that suddenly turns into black holes without any collapse in between.
Indeed. I know that Hawking's equations were "set" using the model of a stable black hole in a vacuum, but there is no vacuum (since the CMBR is always causing SOMETHING to fall into the black hole) and there are no stable black holes (because, Hawking radiation).When the event horizon forms at ##r = 0## and starts moving outward, it won't be producing Hawking radiation (at least according to our best understanding of Hawking radiation), for at least two reasons. First, the horizon is not in vacuum--it is embedded in the collapsing matter. The derivation of Hawking radiation being emitted from a horizon assumes vacuum. Second, the horizon is not a trapped surface--in other words, its area is not constant. The area of the horizon grows until all the collapsing matter has fallen inside it. The derivation of Hawking radiation, if you look at the details, assumes that the horizon is a trapped surface--that its area is not growing.
So this proposed mechanism for stopping a black hole from forming, at least if we use the current understanding of Hawking radiation, won't work. However, it should be noted that our current understanding of Hawking radiation and how it is produced might not be correct.
sevenperforce said:I'd also note that the Schwarzschild radius won't "form" at the center and grow outward
sevenperforce said:a neutron star already has a pretty significant Schwarzschild radius
sevenperforce said:When such a neutron star collapses, the Schwarzschild radius will remain constant while the outer layers fall into it
sevenperforce said:I'd love to get your input over there.
sevenperforce said:there is no vacuum (since the CMBR is always causing SOMETHING to fall into the black hole)
sevenperforce said:applying Hawking's predictions to a Planck-mass model
Sure, I get that.PeterDonis said:The Schwarzschild radius remaining constant is just another way of saying the externally measured mass remains constant. (This assumes that no radiation is emitted during the collapse process, which is highly unlikely in the real world, but we can assume it for this thought experiment.) It does not mean that there is an event horizon sitting there waiting for things to fall in.
I'm not quite sure how this would change the scenario. If there is a particular event at ##r = 0## such that an outgoing light signal emitted from that event would intersect the surface of the collapsing core just at the Schwarzschild radius corresponding to the mass of the core, then you have a core-mass black hole already inside the collapsing neutron star. Similarly, if there is a particular event at ##r = 0## such that an outgoing light signal emitted from that event would intersect the inner-core/outer-core boundary just at the Schwarzschild radius corresponding to the mass of the inner core, then you have an inner-core-mass black hole at the center of the collapsing core.Actually, though, this way of putting things can be misleading. A better way to put it starts with recognizing the definition of the event horizon: it is the boundary of the region of spacetime from which light signals cannot escape. So what is actually happening is that there is a particular event at ##r = 0## such that, if an outgoing light signal is emitted from that event, it will intersect the surface of the collapsing star just at the Schwarzschild radius corresponding to the mass of the system, and will then be trapped there forever, unable to move any further outward.
I would advise rethinking the rest of your proposed scenarios (with varying densities of core vs. outer parts, etc.) in the light of the above.
Well, any analysis might be completely pointless if Hawking radiation predictions break down at a larger scale, but if they don't, then there might be a useful statistical analysis of what would happen as the Planck scale is approached, even if we're not dealing specifically with the Planck mass. For instance, trying to derive the minimum mass by looking at where the math would no longer make sense, like when the peak wavelength of emitted radiation would correspond to a particle energy exceeding half the energy of the object.Hawking's prediction for a Planck mass black hole is that it will evaporate immediately, with no time lapse--i.e., that such a hole can't really exist since it will evaporate as soon as it is formed. This is not something that can be usefully analyzed statistically, as far as I can see.
sevenperforce said:If there is a particular event at r=0r=0r = 0 such that an outgoing light signal emitted from that event would intersect the surface of the collapsing core just at the Schwarzschild radius corresponding to the mass of the core, then you have a core-mass black hole already inside the collapsing neutron star.
sevenperforce said:trying to derive the minimum mass by looking at where the math would no longer make sense
Just so I'm sure we're on the same page -- in the example case, if some event outside the event horizon suddenly arrested the collapse of the outer layers and blasted them away from the growing event horizon, the object left behind would be a static black hole, correct?PeterDonis said:If the rest of the star is going to collapse as well, then the hole won't stay at the Schwarzschild radius of the core; it will keep expanding until all the matter has fallen inside the Schwarzschild radius for the whole star. In other words, yes, while the collapse is happening, you will be able to look at it as a black hole being inside a collapsing star; but it won't be a static black hole inside a collapsing star. So you can't use intuitions that are only valid for static holes, for example about "accretion of matter". Matter is collapsing, and during the collapse more and more matter is inside the growing horizon, but this process is different from the process of accretion of matter onto a hole that has been sitting there static for a long time, surrounded by vacuum, and then suddenly has a large amount of matter fall into it.
As I understand it, this is the problem that Hawking himself runs into with the firewall problem. If Hawking radiation is being produced at or just above the event horizon of a black hole, then an infalling observer would definitely notice the event horizon locally, which isn't actually allowed.A key thing to keep in mind here is that the definition of the event horizon is inherently "teleological"; that is, it depends on what is going to happen in the future. In other words, there is no way to tell locally where the horizon is; to know where it is, you have to know the entire future of the spacetime. So your normal intuitions about objects don't work; you can't think of the horizon as something that is forming because of what already happened. It is forming because of what is going to happen--because all the matter is going to collapse inside the Schwarzschild radius corresponding to its mass. So you can't have a scenario where only part of the matter falls in and then you have a static hole, because if only part of the matter falls in, either the horizon won't form at all, or it won't stay static (as above).
Correct me if I'm wrong, but I thought the Planck mass was the maximum mass for a point particle, since any point particle with a mass greater than the Planck mass will be a black hole.We already know at least a heuristic answer to this: the minimum mass is the Planck mass. There is nothing in the math that shows any problem for any hole larger than that, at least as we understand it today.
sevenperforce said:in the example case, if some event outside the event horizon suddenly arrested the collapse of the outer layers and blasted them away from the growing event horizon, the object left behind would be a static black hole, correct?
sevenperforce said:I thought the Planck mass was the maximum mass for a point particle, since any point particle with a mass greater than the Planck mass will be a black hole.
sevenperforce said:It is narrowly possible to have a black hole which is smaller than the Planck mass but is still within the boundaries of other Planck-scale values. For example, as in the other thread, a black hole of 0.75 Planck masses will have a Schwarzschild radius of 1.5 Planck lengths and an evaporation lifetime which is safely above the Planck time.
My confusion/exception is over the highlighted bit above. Talking about "enough material" doesn't quite make sense because there isn't a minimum-mass black hole, at least not on these scales. There is a minimum mass for a static object to collapse into a black hole, but I'm talking about a collapse which has already physically begun.PeterDonis said:In other words, enough material collapses to form a black hole, just less than the original total mass? Yes, if we assume everything else got radiated away and didn't fall in, what was left behind would be a static black hole with the mass of whatever did fall in.
But a key assumption in your quote above is embodied in the words "the growing event horizon". By specifying that, you are specifying that enough matter is going to fall into make a black hole. So given that specification, it's impossible for a black hole not to form, because you already specified that it did.
Slight modification of that scenario. A large mass is imploding, say 5 solar masses; 1.5 solar masses worth has collapsed inside the Schwarzschild radius for 1.5 solar masses before the rest of the 5 solar masses has collapsed inside the Schwarzschild radius for 5 solar masses, and before the rest of the 5 solar masses can fall in, something arrests the collapse. Is that a possible scenario? If so, that's precisely the scenario I've been interested in from the beginning.To see why this matters, consider an alternate scenario: a large mass is imploding, say 5 solar masses; 1.5 solar masses worth has collapsed inside the Schwarzschild radius for 5 solar masses; but before the rest of the 5 solar masses can fall in, something arrests the collapse and blasts the rest of the mass away. What will be left behind will not be a black hole; it will be a 1.5 solar mass neutron star. And in this case, no horizon will ever form at the center at ##r = 0##. Even if the density there gets higher, temporarily, than the central density of the final 1.5 solar mass neutron star, that won't be sufficient to form a black hole.
Probably not. However, if quantization at the Planck scale produces a model which matches macroscopic behavior on measurable scales (for example, Hawking radiation as tunneling-decay of Planck-scale quantized black holes generating a statistical blackbody curve matching Hawking's predictions for macroscopic black hole thermal radiation spectra), that's useful.Again, I emphasize that all this is heuristic speculation; we do not have a firm theory that says this is how Planck scale physics work. All of these calculations should be taken with a huge helping of salt. They don't really tell us anything except that the Planck scale appears to be the scale at which we expect new physics to emerge. But the Planck scale is twenty orders of magnitude smaller than the smallest scale we can probe with current experiments, so we're not likely to get any data on the matter any time soon.
sevenperforce said:Talking about "enough material" doesn't quite make sense because there isn't a minimum-mass black hole, at least not on these scales.
sevenperforce said:1.5 solar masses worth has collapsed inside the Schwarzschild radius for 1.5 solar masses before the rest of the 5 solar masses has collapsed inside the Schwarzschild radius for 5 solar masses, and before the rest of the 5 solar masses can fall in, something arrests the collapse. Is that a possible scenario?
sevenperforce said:Hawking radiation as tunneling-decay of Planck-scale quantized black holes generating a statistical blackbody curve matching Hawking's predictions for macroscopic black hole thermal radiation spectra
Presumably, the notable exception to this rule would be if some smaller amount of mass were imploded (perhaps by shockwaves in a collapsing star or supernova) at a great enough speed that it collapsed into its own Schwarzschild radius on its own (or at least substantially before the outer shell had done so).PeterDonis said:But there is a minimum mass black hole in the sense that there is no feasible way for an object under the minimum mass limit for a neutron star to collapse to a black hole. That's what I meant when I said "enough material"--there has to be enough mass to be over the maximum mass limit for a neutron star. (The limit for a neutron star is the important one because it is the largest maximum mass limit for any stable configuration that isn't a black hole.)
I haven't seen this described, no. But I figured it would be potentially useful to look at whether modeling a macroscopic black hole as a huge number of Planck scale black holes on the surface of their collective event horizon would match any of the predictions for the spectrum of a macroscopic black hole. Physics has a pretty good record of explaining otherwise-anomalous behavior by figuring out the right scale at which to quantize it (e.g., photoelectric effect). No promise of results, but worth casual investigation.PeterDonis said:I've never seen anything like this described in a peer-reviewed paper. Have you? On its face it doesn't seem feasible; to get a prediction for macroscopic black holes, you have to look at macroscopic black holes, not Planck scale ones. A model of Planck scale black holes can only give you information about the spectrum of Planck scale holes. A macroscopic black hole is not just a huge number of Planck scale black holes mashed together.
sevenperforce said:Presumably, the notable exception to this rule would be if some smaller amount of mass were imploded (perhaps by shockwaves in a collapsing star or supernova) at a great enough speed that it collapsed into its own Schwarzschild radius on its own (or at least substantially before the outer shell had done so).
sevenperforce said:modeling a macroscopic black hole as a huge number of Planck scale black holes on the surface of their collective event horizon
sevenperforce said:No promise of results, but worth casual investigation.
Then...getting back to the OP in this thread...PeterDonis said:If the shock waves end up separating the matter into two disconnected regions, yes, you could look at this as forming a smaller black hole and then having a second shell of matter fall into it (or not, if the shock waves end up blasting the rest of the matter outward fast enough). But the regions have to be disconnected; otherwise, as I said before, you just have a larger black hole in the process of forming.
sevenperforce said:if a neutron star exceeding the ~2 M☉ limit collapses, and this collapse takes place in such a way that the inner core is accelerated inward more rapidly than the rest of the neutron star, then a gap would form
sevenperforce said:If the imploding portion of the detached inner core was small enough, then it is possible that the output of its Hawking radiation could arrest of the collapse of the rest of the object and blast it away in a hypernova, then subsequently evaporate entirely.
sevenperforce said:This could explain the mass gap between neutron stars and black holes
Yeah, I'm familiar with that model, at least in passing. I was going in a slightly different direction, though.PeterDonis said:You might be thinking of a model in which the horizon of a large black hole is modeled as a configuration of a large number of area "quanta", where each quantum of area is 1/4 of the Planck area (the factor 1/4 comes from the calculations by Hawking and Bekenstein in the 1970s, which have been replicated by all other models since).
But not if the initial stage of collapse caused it to implode rapidly enough, right?PeterDonis said:Nope. The inner core would still have to be larger than the maximum mass limit for a neutron star; otherwise it would just become a smaller neutron star.sevenperforce said:If the imploding portion of the detached inner core was small enough, then it is possible that the output of its Hawking radiation could arrest of the collapse of the rest of the object and blast it away in a hypernova, then subsequently evaporate entirely.
sevenperforce said:If Hawking's predictions are correct all the way down to the Planck scale, then there would have to be a minimum-mass black hole not based on the Planck mass, but based on the point at which the Hawking radiation particles would have an energy equal to half the mass-energy of the black hole.
sevenperforce said:not if the initial stage of collapse caused it to implode rapidly enough, right?
PeterDonis said:Have you tried to calculate how rapidly "rapidly enough" would be and how small the resulting black hole could be for a given speed of collapse?
PeterDonis said:we should have ##R_0## as a fairly small multiple of the Schwarzschild radius ##2M##; I will assume ##R_0 = 6M## here
