Gravitational Effects on a Pendulum in a Moving Ship
16 replies · 4K views · last reply
Viraam
A pendulum having a bob of mass ##m## is hanging in a ship sailing along the equator from east to west. If the ship sails at speed v what is the tension in the string?. Angular speed of Earth's rotation is ## \omega ## and radius of the Earth is ## R ##
## T = mg - R\omega'^2##
If the ship were still, the tension in the string would be given by
## T_0 = mg - mR\omega^2##
However since the ship moves in the direction opposite to Earth's rotation, the angular velocity of Earth with respect to the ship would be ## \omega + \frac{v}{R}##
Therefore the tension would be
## T = mg - mR(\omega + \frac{v}{R})^2 \\
T \approx T_0 - 2m\omega v
Doubt: The answer key says that ## T \approx T_0 + 2m\omega v ## which means the relative angular velocity was taken as ## \omega - \frac{v}{R} ## . But isn't that the relative angular velocity when the ship sails from west to east. Where did I go wrong?
Here:
In which direction does the Earth spin?
The Earth spins from west to east.
So if you in addition give yourself a velocity from west to east, how does this affect your angular velocity? Will you get a larger or smaller angular velocity?
Ohhh yes. Intuitively, I feel it would be a larger angular velocity.
But if you talk about relative motion, then won't the values get subtracted as they are along the same direction.
Orodruin said:
Relative to what?
Angular velocity of the Earth relative to the ship.
The angular velocity of the Earth relative to the ship is ##v/r##. What you want is the angular velocity of the ship relative to an inertial frame.
I don't quite get it. It the angular velocity of the Earth relative to the ship = ## \omega_\text{earth}-\omega_\text{ship} ##. Say for instance, my frame of reference is that of the ship which is non inertial.
From the free body diagram, I get the relation ## T = mg - mR\omega^2 ##. But in this case, shouldn't omega be the relative angular velocity of the Earth with respect to the ship.
  • Free-body diagram of a block on the rim of a large light-blue circle, with arrows labelled mg pointing toward the centre, T pointing outward and mRω² pointing outward.
Yes, and by definition of your problem where the ship is moving at speed ##v## relative to the Earth that relative angular velocity is ##-v/r## so ##\omega_{\rm ship} = \omega_{\rm earth} + v/r##.
No. It should be the angular velocity relative to an inertial frame.
Orodruin said:
Yes, and by definition of your problem where the ship is moving at speed vvv relative to the Earth that relative angular velocity is −v/r−v/r-v/r so ωship=ωearth+v/rωship=ωearth+v/r\omega_{\rm ship} = \omega_{\rm earth} + v/r.
Ohh ok. Let me just repeat what I understand from your explanation. Can you please tell me if I understood right?
Since the ship is on Earth the velocity ## v ## given to us is actually its velocity relative to earth. Hence,
## -\dfrac{v}{R} = \omega_\text{ship} - \omega_\text{earth} \\ \Rightarrow \omega_\text{ship} = \omega_\text{earth} - \dfrac{v}{R} ##
And this is ## \omega_\text{ship} ## is to be used in the equation ## T = mg - mR\omega^2 ##
Viraam said:
Hence,
No. You mixed ip the signs again. What I gave you was the relative angular velocity given in post #9 ie earth-ship, not ship-earth. You need to be more careful when you consider those.
I'm sorry but I'm quite confused right now. If I use
in ## T = mg - mR\omega^2 ## then I get the result which I posted in the question of this thread:
Viraam said:
However since the ship moves in the direction opposite to Earth's rotation, the angular velocity of Earth with respect to the ship would be ω+vRω+vR \omega + \frac{v}{R}
T=mg−mR(ω+vR)2T≈T0−2mωvT=mg−mR(ω+vR)2T≈T0−2mωv T = mg - mR(\omega + \frac{v}{R})^2 \\ T \approx T_0 - 2m\omega v
However, the answer is ## T \approx T_0 + 2m\omega v ## in the textbook. From their answer I inferred that they must have taken ## \omega_\text{ship} = \omega - \dfrac{v}{R}##
Sorry for the trouble again!
I thought you were still discussing west to east motion of the ship.
Oops! My bad. I didn't mention which case I was talking about. Sorry!
When I wrote the following, I meant the case when the ship was sailing from east to west: -
## -\dfrac{v}{R} = \omega_\text{ship} - \omega_\text{earth} \\ \Rightarrow \omega_\text{ship} = \omega_\text{earth} - \dfrac{v}{R}##
Is it correct now?​
Yes, since the ship moves in the opposite direction of the Earth's angular velocity, its velocity relative to the Earth's surface will tend to give it a lower angular velocity relative to an inertial frame.
Thanks a lot. I've understood the solution to this problem now!
