Gravitational Force Problem - Help
6 replies · 2K views
SpacemanRich
As a moon follows it's orbit around a planet, the maximum gravitational force exerted on the moon by the planet exceeds the minimum gravitational force by 11%. Find the ratio rmax / rmin, where rmax is the moon's maximum distance from the center of the planet and rmin is the minimum distance.
Newton's law of Gravitation F = G m1m2 / r2
I found the ratio to be, rmax / rmin = 0.949 to 3 significant digits.
My textbook says the ratio is 1.05. I think the text if wrong. Can someone try this problem and let me know what you get.
Thanks,
R.
Thanks,
R.
If rmax / rmin < 1, then rmax < rmin .
Does that make any sense?
Where is the gravitational force greater, at rmin or at rmax?
Thanks,
R.
At first I thought you were right, but there is an ambiguity in the notation. Is rmax the radius where the force is max, or is it the maximum radius? You get the two different answers depending on how you define the subscripts of the radius variable...
The gravitational force is greatest at rmin.
The confusion was over whether rmin meant the point where the moon is closest to the planet, or if it meant the variable r of the Gravitational formula for Fmin. From the responses I got, I was not the only one confused by the wording of the problem.
I'm glad I was not the only one confused by the wording of the problem. The hint given by kreil clarified it, and the problem works out fine then. Thanks for your input.
kreil said:
Hint
[tex]F_{max} = \frac{Gm_1m_2}{r_{min}^2}[/tex]
That makes it perfectly clear what I was missing when reading the problem. Now the problem works as expected.
Thanks for opening my eyes..
Regards,
Rich
