Gravitational net force of zero
To achieve a net gravitational force of zero on a 50 kg mass placed between a 200 kg and a 500 kg mass, the forces exerted by both larger masses must be equal. The calculations involve setting the gravitational forces equal and solving for the distances from the 50 kg mass to each of the other masses. The correct placement is approximately 0.245 m from the 500 kg mass and 0.155 m from the 200 kg mass. A more efficient method involves using a derived formula that simplifies the calculations without needing to solve a quadratic equation. Overall, the approach and final answer are confirmed to be correct.
UrbanXrisis
A 200 kg mass and a 500kg mass are separated by 0.4m. At what position can a 50kg mass be placed so as to experience a net force of zero (other than infinity)?
here's what I did:
I need both forces to equal each other.
F_{200}=G\frac{200m}{x^2}=G\frac{500m}{y^2}=F_{500}
\frac{200}{x^2}=\frac{500}{y^2}
200y^2=500x^2
x+y=0.4
x=0.4-y
500(0.4-y)^2=200y^2
500(0.16-0.8y+y^2)=200y^2
200y^2=80-400y+500y^2
1=\frac{0.4}{y^2}-\frac{2}{y}+2.5
y=0.245m,x=0.155m
did I do this correctly? was there a faster way?
Your question isn't clear,are you trying to balance the entire system? How many dimensions here, 1 or 2? Do you want just the 50kg to experience no force? It looks like your talking about gravitational forces among the 3, right?
well, I copied the book. What I got was that I had to place the 50kg mass in between the 200kg and 500kg masses so that the 50kg mass experiences a net force of zero.
then you want the pull from left to equal the pull from the right. Though I didnt check your math, the method is right and your answer seems logical.
Are the CORES of the masses separated by 0.4m or just surface to surface? Anyway if it is the cores, don't bother with two variables. Say one will be x, the other 0.4-x.
Look:
GM1/(0.4-x)^2=GM2/x^2
So
M1/(0.4-x)^2=M2/x^2
So
M1x^2=M2(0.4-x)^2
SO
(M1^0.5)x=M2^0.5(0.4-x)
-((M1^0.5)x/M2^0.5)+0.4=x
-((M1^0.5)/M2^0.5)+0.4/x=1
-((M1^0.5)/M2^0.5)-1=-0.4/x
x=0.4/((M1^0.5)/M2^0.5)-1
It would have been faster if you knew this formula!
Since the radius of each mass isn't provided, you are forced to assume that it is core to core.
In this case my guess was good :)
Theres a mistake in the algebra somewhere there. The answer should have + 1, not -1.
so
0.4/x =1 + ((M1^0.5)/M2^0.5)
x = 0.4 / ( 1+ ((M1^0.5)/M2^0.5))
So far, so good. (Assuming these masses can be treated as particles.) Simplifying and rewriting this in standard form for a quadratic:
15y^2 -20y + 4 = 0
Which yields two solutions, only one of which is relevant to this problem.
I don't know why you wrote it this way.
y=0.245m,x=0.155m
Perfectly correct.
It would have been slightly faster to immediately take the (positive) square root (as Werg22 showed), which eliminates the need to solve a quadratic:
\frac{200}{x^2}=\frac{500}{y^2} \; \Longrightarrow \; \frac{2}{x^2}=\frac{5}{y^2}
becomes:
\frac{\sqrt{2}}{x}=\frac{\sqrt{5}}{y}
Sorry guys! It is actually because I forgot the 1 was an individual term... I tought it was part of the parenthesis when it is not.
  • · Replies 30 ·
