Gravitational potential energy in GR
Zman
I read that General Relativity reduces to Newtonian when v<<c as well as when Newtonian gravitational potential energies are small compared to mc^2.
What is the GR version of gravitational potential energy?
In GR, the local time rate near massive objects varies compared with the time rate of a distant observer. This effectively causes a fractional change in the rest energy of a test body when it is moved into that potential, which corresponds to the Newtonian potential energy. For the potential at distance r from a central mass M, the relative time rate is approximately (1-GM/rc2) so the potential energy is a fraction -GM/rc2 of the rest energy, or a fraction -GM/r of the test body rest mass, as in Newtonian theory.
This approximate scheme doesn't however work when the potential energy of the source is considered as well as that of a test object, because a simple approximation to GR would suggest that their potential energy due to each other is equal, which means that when the test mass was brought near to the source mass the total energy of the system has been decreased by twice the Newtonian potential energy. In Newtonian theory, we understand that potential energy is a property of the system, so we should only count it for one or the other object, but it is not clear (at least to me) how to correct the GR approximation to allow for this.
Thanks very much for your input. I can see what is meant now by the GR version of gravitational potential energy.
It is interesting how ‘clock rates’ can be directly translated into potential energy.
Rest energy E = (1-\frac{GM}{rc^2})mc^2=mc^2-\frac{GMm}{r}
But (1-\frac{GM}{rc^2}) is a clock rate ratio. Can multiplying a clock rate ratio by mc^2 be justified?
Regarding your last point about GR and twice the potential energy, doesn’t one choose a reference frame in GR? Taking a system wide approach sounds more like a Newtonian approach.
Energy is related to frequency by Planck's constant: E = h\nu = \hbar \omega; If time is running slower in one place relative to another, the energy of objects at that place is decreased in the same proportion. For the simplest comparison with Newton's theory, we can take the reference point to be somewhere "distant". As a first order approximation, we can also take the ratio of the clock rate at two points within the potential to get a Newtonian potential difference:
<br /> \frac{1-Gm/r_1\, c^2}{1-Gm/r_2\, c^2} \approx {1-Gm/{r_1\, c^2} + Gm/{r_2\,c^2}}<br />
In both Newtonian theory and GR, energy is relative to a particular observer frame. Making it add up in a sensible way in GR is an extremely advanced and somewhat speculative topic.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
