High School Gravity: How Does It Work & What Causes It?
  • Thread starter Thread starter timeuser84
    Gravity Work
Gravity is understood through both Newtonian mechanics and Einstein's General Relativity, with Newton's law providing a simpler approximation for everyday applications. While Newton's law describes gravity as a distant force without a clear transmission mechanism, General Relativity conceptualizes gravity as the curvature of space-time caused by mass. The discussion highlights the need for a deeper understanding of gravitational theories, emphasizing that scientific models are based on assumptions that may evolve as new evidence emerges. The complexities of gravity also include the interaction of gravitational fields with energy, leading to the idea that "gravity gravitates." Overall, the conversation underscores the importance of refining questions about gravity to facilitate more focused discussions on its mechanisms.
timeuser84
Hi, I don't know if I am in the right part of this forum to ask so if not please move my thread to the appropriate area. I do understand how gravity works on a very basic laymen level like the old Newton apple tree example but beyond that, nothing more.
Newton formulates the universal gravitation law as
F=-G\frac{Mm}{r^2}
where gravity is distant force, i.e. no mechanism of transmission is explained.
Later electric force was found to have similar fashion
F=k\frac{Qq}{r^2}
Electric force was found to have nature of locality i.e. charge has power to cause electric field and it transmits with finite speed of c. Along with it Einstein formulates the locality of gravity in his general theory of relativity in 20th century.
Your question as it stands is too broad to know what the best forum would be to answer it. See below.
There is so much more beyond that that, as noted above, your question as it stands is too broad to be able to usefully answer it here; you would need to take several semesters of physics classes. So we need to try to pin your question down more.
Our best current theory of gravity is General Relativity. However, for many purposes, Newtonian gravity, the theory that Newton discovered following his apple experience, and which was developed over the next couple of centuries by many other physicists, is a good enough approximation and GR is not necessary. Newtonian gravity is also considerably easier to learn and understand.
So the first way to help pin down your question is, are you interested in learning about Newtonian gravity? Or General Relativity?
The second way to help pin your question down is, instead of just asking "how does gravity work" in general, you might want to try to think of a specific scenario, like the falling apple, and focus on that. Can you think of one?
Likes russ_watters and bhobba
Beyond what's been said already, it's important to understand that science aims to accurately describe reality using logic and mathematics. Even theories or descriptions that are 'wrong' are still often used because they are simpler than their replacements and may be 'right enough' for certain applications. A good example is Newtonian gravity. We know it is 'wrong', as we have observable evidence that contradicts it AND we have another theory that accurately predicts and describes the contradictory evidence. However, Newtonian gravity is far simpler than its replacement, General Relativity, and is 'good enough' for everyday purposes like building bridges, buildings, and operating vehicles.
Likes bhobba
I will give a slightly different take based on the first university level book on gravitation I read many years ago - simply called - Gravitation and Space-Time:
https://www.amazon.com/dp/1107012945/?tag=pfamazon01-20
You probably have heard of Coulombs law:
https://en.wikipedia.org/wiki/Coulomb's_law
Well there is an issue with it and relativity. You probably have heard that in relativity nothing can move faster than the speed of light:
https://en.wikipedia.org/wiki/Special_relativity
So let's move a charge, then according to Coulombs law the field moves instantaneously even many miles away. But since nothing can move faster than light this can not be correct. One can fix this up by carefully analysing what a theory that takes into account relativity would be like. It's advanced but just to show it can be done here are the details:
http://www.cse.secs.oakland.edu/haskell/Special Relativity and Maxwells Equations.pdf
These are the so called Maxwell's Equations and are the correct equations of an electric field that fixes the problem with relativity. It also introduces a new field - the magnetic field - which you undoubtably have experience with using bar magnets etc. Light, radio waves etc are all forms of electromagnetic radiation from the fact Maxwell's equations show accelerating charges actually radiate EM fields. It is the basis of all our electrical technology, and the bread and butter of any electrical engineer.
You also have probably heard of Newtons law of gravitation:
https://en.wikipedia.org/wiki/Newton's_law_of_universal_gravitation
Notice it is similar to Coulomb's law and has exactly the same problem. So by looking at Maxwell's equations, in an analogous way we can fix up Newtons law of Gravitation, and you end up with what is called linearised gravitation. It predicts all sorts of new effects such as the bending of light around the sun, slight discrepancies in the orbits of planets etc - all of which have been confirmed by experiment. Great - you think that's it. Well not quite - when you analyse linearised gravity you find a problem. It says all matter and energy can be a source of gravitation. But there is a powerful theorem called Noether's theorem that says fields themselves should have energy (the following is a bit about Noether and her beautiful theorem that is now so fundamental to much of physics):
https://www.vox.com/2015/3/23/8274777/emmy-noether
So that means the gravitational field itself should act as a source of gravity - sometimes called gravity gravitates. Hence linearised gravity, which does not take this into account, can only work when gravitational fields are weak and this can be neglected. So we need to fix this up. In doing this we find something very interesting about linearised gravity. It acts as if space-time had a very small curvature. So, to fix it, we try to find the equations of space-time with an arbitrary curvature and hope that will get us out of trouble. It turns out linearised gravity has a rather strange property - only one set of equations with arbitrary curvature exists that reduce to linearised gravity when the field is weak - the so called Einstein Field Equations, and it turns out those equations do indeed include gravity gravitating. Changing the perspective to gravity being space-time curvature in an intuitive sense makes the problem go away. These are the equations of General Relativity that Einstein and independently the great mathematician Hilbert discovered. But Hilbert, being a mathematician, magnanimously gave the credit to Einstein because as he said 'every child in the streets of Göttingen knows more about four-dimensional geometry than Einstein', but it was Einstein's physical insight that got him to the key ideas, and hence deserved the credit. However they did it by different means than I described above. Indeed if you asked a slightly different question - what is the simplest explanation of our current theory of gravity - I would have explained it more in line with the usual presentation - but the above shows how science progresses by finding issues with current theories and tries, in a reasonable way, to fix them. How Einstein/Hilbert did it you will find in most books on General Relativity - the book I got this from is the odd one out. Einstein had the uncanny ability to deeply penetrate issues in physics and this led him to a different way of solving it using thought experiments with elevators etc - not the clean logical way I presented it. But what I described above I think answers your question better. Namely its the reasonable consequence of trying to fix up Newtonian gravity in a way similar to fixing up Coulomb's law.
There is an issue with asking in science how does something like electricity or gravity work. We have theories - which is what gravitational theory is - a theory. Every theory has assumptions. Sometimes you find those assumptions are 'wrong' like with Coulomb's Law and Newtonian Gravity, so have to be modified and based on different assumptions. Then you have a new and better theory - but it is still based on assumptions. Doesn't matter what you do you must assume something. So asking how does something fundamental like gravity work is to some extent meaningless - at rock bottom it's based on a theory and what it says is a consequence of the assumptions it makes. We constantly check those assumptions, and their consequences, against experiment to see if they are valid, logically consistent, in accord with other theories etc. So it's provisional and hence can't be said to be how gravity works - it's simply a model that explains all the observations/experiments etc we currently know. But physicists are like everyone else, sloppy on occasion, and will say things like space-time curvature is how gravity works. But now you know what is actually going on in science and recognise that is not strictly true.
Thanks
Bill
Likes anuttarasammyak and weirdoguy
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 33 ·
  • · Replies 81 ·
9K
  • · Replies 18 ·
  • · Replies 46 ·
  • · Replies 19 ·
