Gravity inside an exponential mass disk
The discussion revolves around understanding the gravitational effects inside an exponential axisymmetric mass disk with no thickness. Participants explore various methods to calculate gravitational forces and fields, referencing existing models like the Mestel disk and Kuzmin model, while seeking simpler solutions.
  • One participant proposes using linear superposition to analyze the gravitational force on a mass within the disk, considering contributions from both inside and outside the radius.
  • Another participant questions the representation of the mass density curve, asking for clarification on the formula for surface density.
  • Some participants express confusion regarding the terms "exponential asymmetric" and "surface density," leading to further explanations about mass density decay and axisymmetry.
  • A participant suggests using Green's function to solve the Newtonian field equation, while another inquires about simpler methods.
  • Discussion includes the complexity of the Kuzmin model, with some participants arguing it is simpler than suggested, while others seek even simpler alternatives.
  • Participants discuss the gravitational potential and field intensity derived from the Kuzmin model, with one providing the mathematical formulation for the gravitational potential and its implications.
Participants express differing views on the complexity of the Kuzmin model and the methods for calculating gravitational effects. There is no consensus on a single approach or model, and multiple competing views remain throughout the discussion.
Participants reference various mathematical formulations and models, indicating a reliance on specific assumptions about mass distribution and symmetry. The discussion does not resolve the complexities involved in the calculations or the interpretations of the models.
independentphysics
I am trying to understand gravity inside an exponential axysymmetric mass disk with no thickness.
I know there are exact solutions for this case, such as the Mestel disk or the Kuzmin model, but I want to work out a simpler solution.
I am approaching the subject by linear superposition. For a mass m inside the disk at a distance r from the center, the gravitational force experienced by the mass m can be divided into the force from the mass M(r) inside the radius r (1), and the force from the mass outside r (2) (see attached image). Due to symmetry, I restrict the solution to a unique axis.
My understanding is that the total gravitational force experienced by the mass m pointing towards the center to the disk, is smaller than the one applying shell theorem (a spherically symmetric body affects external objects gravitationally as though all of its mass were concentrated at a point at its center). Also, it is smaller than the gravitational forced experienced only by the mass inside the radius r (case (1)).
What about gravitational field intensities? My understanding is that the gravitational field intensity at a distance r is bigger than just for case (1). Is it also bigger than for the case of all the mass of the disk concentrated at a point?
Astronomy news on Phys.org
Curve in your figure seems linear not exponential to me. Could you give us formula of ##\rho(r)## ?
It is certainly not. I dont care much about the form of surface density (linear or exponential) as long as it is not a solid disk (which is a completely different case of study).
I am not good at getting meaning of your "exponential asymmetric" and "surface density".
Exponential decay of mass density from center.
Axisymmetric disk (not elliptical disk)
Surface density = mass density function, since I consider no thickness mass/distance^2
Thanks. So I assume the setting as
[tex]\int_0^R \sigma(r) 2 \pi r dr = M[/tex]
where
[tex]\sigma(r)=\sigma(0)e^{-\alpha r/R}[/tex]
[tex]\alpha= -\log \frac{\sigma(R)}{\sigma(0)}[/tex]
R is radius of thin disk, M is its mass.
Then just use the Green's function of the Laplace operator to solve the Newtonian field equation,
$$-\Delta \Phi=-4 \pi \gamma \rho=-4 \pi \gamma \sigma \delta(x_3),$$
leading to
$$\Phi=-\gamma \int_{K_r} \mathrm{d}^2 f' \frac{\gamma \sigma(\vec{r}')}{|\vec{r}-\vec{r}'|}.$$
  • Love
where
Yes.
leading to
I am solving it through superoposition. Isnt there a more simple way to do it?
Not only inside disk and outside ring of your suggestion, but decomposition to the inifinitesimal rings seem to work.
On X-Y plane there is a ring of radius r centered on Origin. Gravity potential at (x,0) is
[tex]d\phi(x:r,\sigma)=-Gr\ dr\ \sigma \int_0^{2\pi}[r^2 \sin^2\theta+(x-r\cos\theta)^2]^{-1/2}d\theta[/tex]
where ##\sigma## is surface density of mass. x<r, x=r and x>r work. Gravity potential of disk which consists of the rings is geiven by superposition,i.e.,
[tex]\phi(x)=\int_{r=0}^{r=\infty} d\phi(x:r,\sigma(r))[/tex]
I am afraid there is no simpler way as you expect so.
If it is axisymmetric, why bother with angles?
Disance to the observing point depends on the angle. After integration the result contanins no angle parameter because of symmetry.
The Kuzmin model is just one of many. If you want more precise approximations, there are many more for thickened disks. Im just looking for a more simple one than Kuzmin.
The Kuzmin model is very simple, because one simply makes an ansatz for the gravitational potential. It's just a solution of the Laplace equation with two "mirror charges", i.e., and a singularity along the ##xy## plane
$$\Phi(\vec{r})=\begin{cases} -\frac{G M}{|\vec{r}+a \vec{e}_z|} & \text{for} \quad z>0, \\ -\frac{GM}{|\vec{r}-\vec{a} \vec{e}_z|} & \text{for} \quad z<0. \end{cases}$$
It fufills indeed ##\Delta \Phi=0## for all ##\vec{r}## not on the ##xy## plane, along which it has a singularity, which is calculated in the quoted link. The source is
$$\rho(\vec{r})=\Delta \Phi(\vec{r})=\frac{M a}{2 \pi \sqrt{x_1^2+x_2^2+a^2}}\delta(z),$$
i.e., a surface-mass density,
[EDIT: Typo corrected]
$$\sigma(\vec{r})=\frac{M a}{2 \pi \sqrt{x_1^2+x_2^2+a^2}}.$$
$$\rho(\vec{r})=\Delta \Phi(\vec{r})=\frac{M a}{2 \pi |x_1^2+x_2^2+a^2}\delta(z),$$
$$\sigma(\vec{r})=\frac{M a}{2 \pi |x_1^2+x_2^2+a^2}.$$
What is the gravitational field intensity in the Kuzmin model in terms of r?
It's just the gradient of the potential,
$$\vec{g}(\vec{r})=-\vec{\nabla} \Phi(\vec{r})=\begin{cases} -\frac{GM}{|\vec{r}+a \vec{e}_z|^3} (\vec{r}+a \vec{z}) &\text{for} \quad z>0, \\
-\frac{GM}{|\vec{r}-a \vec{e}_z|^3} (\vec{r}-a \vec{z}) & \text{for} \quad z<0.\end{cases}$$
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 86 ·
10K
