GRE question: Young's Double Slit Experiment
1 reply · 3K views · last reply
AriAstronomer
Consider a young double slit experiments where the two slits are spaced d = 0.1mm apart. If when the screen is at a distance of l=1m the first bright maximum is displaced y = 2cm from the central maximum, then find the wavelength of the light.
dsin(theta) = m(lambda)
I use the small angle approximation, tanx = sinx = x = y/D.
dy/D = m(lambda), where d = 0.1mm, D = 1m, y = .02m, m=1, and I get lambda = 2000nm, but the solution manual says that the answer is 5000Angstroms. They say lambda =[ d/l ]*(dy) = [(10^-4)/2 ]*(10^-2), but I don't really see where they're getting these numbers from. Any idea?
Nope, but your solution is perfectly correct. The author probably screwed up and used the wrong numbers in writing the answer key.
