Tracing the Light Path of a Green Laser Pointer
The visibility of the light path of a green laser pointer is primarily due to the higher sensitivity of the human eye to green light compared to red light, with a sensitivity increase of over ten times. The scattering of the laser beam occurs as it interacts with dust, smoke, and water vapor, allowing the beam to be seen from various angles. Additionally, Raleigh backscattering plays a significant role, particularly at high laser intensities, where green light reflects more effectively than red light due to its fourth power dependence on wavelength. High power Argon-ion lasers in light shows exemplify this phenomenon.
  • Understanding of light scattering principles
  • Knowledge of laser types, specifically Argon-ion lasers
  • Familiarity with human visual sensitivity to different wavelengths
  • Basic concepts of Raleigh backscattering
  • Research the properties of Argon-ion lasers and their applications in light shows
  • Study the principles of light scattering and its effects on visibility
  • Explore the human eye's sensitivity to various wavelengths of light
  • Investigate Raleigh backscattering and its mathematical implications
Physicists, optical engineers, educators in physics, and anyone interested in the behavior of laser light and its visibility in different environments.
Frannas
How is it possible to see the light path of a green laser pointer?
Science news on Phys.org
Your eye is more sensitive to green than, say, red.
Also as the laser beam travels, dust and other particles are in the way. This causes a scattering of the beam, allowing you to see it from behind or from the side or indeed from most any angle.
Usually reflection off of matter (dust, smoke, water vapor etc), but can be Raleigh backscattering (off of air molecules) if the laser intensity is high enough.
I'm guessing your question is aimed (pardon the pun) at the latter effect. Green lasers will have a light path that is more visible than a red light in clear air for several reasons.
1. The laser power is often higher. (I'm thinking of those high power Argon-ion lasers in light shows)
2. Eyes are >10 times more sensitive to green light than red light.
3. Raleigh backscattering has a 4th power dependence on wavelength resulting in green light reflecting much better than red light by about a factor of 3.
  • · Replies 23 ·
