Green's function and the evolution operator
33 replies · 6K views
Quick correction from my previous derivation: Sign error by me, such that ##\omega = \frac{\hat{H}}{\hbar}##, which for natural unts, ##\omega = \hat{H}##.I will go through the derivation.Equation 17.21:
\begin{equation}
\begin{split}
| \psi_t \rangle &= e^{-\frac{i}{\hbar} \hat{H} (t-\acute{t})} | \psi_{\acute{t}} \rangle
\end{split}
\end{equation}Given:
\begin{equation}
\begin{split}
\omega &= \frac{\hat{H}}{\hbar}
\end{split}
\end{equation}\begin{equation}
\begin{split}
| \psi_t \rangle &= e^{-i \omega (t-\acute{t})} | \psi_{\acute{t}} \rangle
\end{split}
\end{equation}
Which is my version of the time evolution operator, ##\hat{U}(t,\acute{t})##.Equation 17.26:
\begin{equation}
\begin{split}
\left( i\hbar \frac{\partial}{\partial t}-E_j \right ) G_j^{+}(t,\acute{t}) &=\delta(t-\acute{t})
\end{split}
\end{equation}Where:
\begin{equation}
\begin{split}
G_j^{+}(t,\acute{t})&=-\frac{i}{\hbar} e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t})
\end{split}
\end{equation}Such that:
\begin{equation}
\begin{split}
\left( i\hbar \frac{\partial}{\partial t}-E_j \right ) G_j^{+}(t,\acute{t}) &=\left( i\hbar \frac{\partial}{\partial t}-E_j \right ) \left(-\frac{i}{\hbar} e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t}) \right)
&=\left( \frac{\partial}{\partial t}+ \frac{i}{\hbar}E_j \right ) \left( e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t}) \right)
\end{split}
\end{equation}And:
\begin{equation}
\begin{split}
\left( \frac{\partial}{\partial t}+ \frac{i}{\hbar}E_j \right ) \left( e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t}) \right)&=\delta(t-\acute{t})
-i\left( \frac{\partial}{\partial t}+ \frac{i}{\hbar}E_j \right ) \left( e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t}) \right)&=-i \delta(t-\acute{t})
\left(-i \frac{\partial}{\partial t}- \frac{E_j}{\hbar} \right ) \left( e^{-\frac{i}{\hbar} E_j (t-\acute{t})} \theta(t-\acute{t}) \right)&=-i \delta(t-\acute{t})
\end{split}
\end{equation}
Given ##\omega_j=\frac{E_j}{\hbar}## and ##\partial_t = \frac{\partial}{\partial t}##:
\begin{equation}
\begin{split}
\left(-i \partial_t- \omega_j \right ) \left( e^{-i \omega_j (t-\acute{t})} \theta(t-\acute{t}) \right)&=-i \delta(t-\acute{t})
\end{split}
\begin{equation}
\begin{split}
e^{-i \omega_j (t-\acute{t})} \theta(t-\acute{t})&=G_j^{+}(t,\acute{t})
\end{split}
\begin{equation}
\begin{split}
\left(-i \partial_t- \omega_j \right ) G_j^{+}(t,\acute{t})&=-i \delta(t-\acute{t})
\end{split}
\end{equation}Again, this is the same as my derivation.Equation 17.28:
\begin{equation}
\begin{split}
G^+(\vec{r},t;\vec{\acute{r}},\acute{t})&=-\frac{i}{\hbar}\sum_j e^{-\frac{i}{\hbar}E_j (t-\acute{t})}\theta(t-\acute{t})u_j(\vec{r}) u_j^*(\vec{\acute{r}})
\end{split}
\end{equation}Equation 17.31:
\begin{equation}
\begin{split}
\left(i\hbar \frac{\partial}{\partial t} -\hat{H} \right) G^+(\vec{r},t;\vec{\acute{r}},\acute{t})&=-\frac{i}{\hbar}\sum_j \left(i\hbar \frac{\partial}{\partial t} -E_j \right) G_j^+(t-\acute{t}) u_j(\vec{r}) u_j^*(\vec{\acute{r}})
&=\sum_j \delta(t-\acute{t})u_j(\vec{r}) u_j^*(\vec{\acute{r}})
&=\delta(t-\acute{t})\delta^3(\vec{r}-\vec{\acute{r}})
&=\delta^4(\vec{x}-\vec{\acute{x}})
\end{split}
\begin{equation}
\begin{split}
\sum_j u_j(\vec{r}) u_j^*(\vec{\acute{r}})&=\delta^3(\vec{r}-\vec{\acute{r}})
\end{split}
\end{equation}And:
\begin{equation}
\begin{split}
G^+(\vec{r},t;\vec{\acute{r}},\acute{t})&=\sum_j G_j^+(\vec{r},t;\vec{\acute{r}},\acute{t})
&=\sum_j G_j^+(t-\acute{t}) u_j(\vec{r}) u_j^*(\vec{\acute{r}})
&=\sum_j G_j^+(t-\acute{t})\delta^3(\vec{r}-\vec{\acute{r}})
&=G^+(t-\acute{t})\delta^3(\vec{r}-\vec{\acute{r}})
&=-\frac{i}{\hbar} e^{-\frac{i}{\hbar} E (t-\acute{t})} \theta(t-\acute{t})\delta^3(\vec{r}-\vec{\acute{r}})
&=-\frac{i}{\hbar} e^{-i \omega (t-\acute{t})} \theta(t-\acute{t})\delta^3(\vec{r}-\vec{\acute{r}})
\end{split}
\end{equation}Which is the SAME expression for the Green function that I derived (assuming some algebra with ##i## and ##\hbar##, which I demonstrate above). In other words, the result is the same. Trying to distinguish my derivation from the one in the paper by asserting one involves position and the other energy in order to accept one and not the other is simply not tenable.
redtree said:
Quick correction from my previous derivation: Sign error by me, such that ω=^Hℏω=H^ℏ\omega = \frac{\hat{H}}{\hbar}, which for natural unts, ω=\hat{H}.
Regardless of the sign, it is simpy not true. It is only true on a degenerate subspace of the Hamiltonian, which you generally do not have.
It is very tenable. You get different results and your's is wrong. Not only are you assuming that the position eigenstates are energy eigenstates (they are not), you are also asserting that they all have the same energy.. The Green's function for ##t > t'## is not proportional to a delta function in space.
