Green's functions: Logic behind this step
4 replies · 2K views
WWCY
Hi all,
I came across these steps in my notes, relating to a step whereby,
$$\hat{G} (k, t - t') = \int_{-\infty}^{\infty} e^{-ik(x - x')}G(x-x' , t-t')dx$$
and performing the following operation on ##\hat{G}## gives the following expression,
$$[\frac{\partial}{\partial t} - D\frac{\partial ^2}{\partial x^2}] \hat{G} = \frac{\partial \hat{G}}{\partial t} + Dk^2 \hat{G}$$
These steps are in the context of a more complex problem of solving the Heat Equation using the Green's function.
I can partially understand the writing of ##\frac{\partial \hat{G}}{\partial t}## at the LHS as the same thing, ##\frac{\partial \hat{G}}{\partial t}## at the RHS; we do not know how ##G## (found in the first integral) depends on time exactly.
But the other terms that imply ##- D\frac{\partial ^2 \hat{G}}{\partial x^2} = Dk^2 \hat{G}## I can't follow. First of all, we don't know how ##G## varies with ##x##. Add to that that the fact that the integral isn't independent of ##x##, I don't see how we can apply differentiation under the integral sign to bring down the factor of ##(-ik)^2## down from ##e^{-ik(x-x')}##
Could someone explain the logic behind the steps? Help is greatly appreciated!
##\hat G## does not depend on ##x## (it is an internal integration variable). The equation you quoted is not true. What is true is that
\partial_t \hat G + k^2 D \hat G
is the Fourier transform of the left-hand side of the heat equation.
Hi @Orodruin , am I right to say that ##\hat{G}## has no explicit dependence of ##x## as it is the Fourier transform of ##G##?
Do you also mind illustrating how the factor of ##(-ik)^2## was brought down?
Thanks for your assistance.
Yes.
This is a general property of the Fourier transform. In general, for any function ##f(x)##, it holds that
F[f'] = \int f'(x) e^{-ikx} dx = - \int f(x) \frac{de^{-ikx}}{dx} dx = ik \int f(x) e^{-ikx} dx = ik F[f],
where ##F[f]## is the Fourier transform of ##f##.
Orodruin said:
Yes.This is a general property of the Fourier transform. In general, for any function ##f(x)##, it holds that
Thank you!
