Grounding by touching a ground lead
  • Context: High School
  • Thread starter Thread starter rasen58
    Ground Grounding Lead
3 replies · 1K views
rasen58
Is it possible to sufficiently ground yourself just by touching the negative lead of a wire coming from a power supply once?
No you need to stay connected to be grounded, and it needs to be to Earth ground.
If you are wearing a wool sweater on a dry day, you will charge back up within a few seconds of moving around after touching the ground lead. If you're not doing anything that charges you back up, it will take a while for any charge to build up on you again.
BTW, it's good practice to ground yourself though a large value resistor like 1 MegOhm. This reduces the possibility that you can get shocked badly if you happen to be connected to some other voltage. ESD control wriststraps, for example, contain such a current-limiting resistor.
Plus, the negative lead from the PSU may not be grounded ( ie. its " floating")
