Groups do not necessarily have to have only one operation
  • Thread starter Gear300
  • Tags
    Groups
In summary, groups do not necessarily have only one operation, but there is one operation that they are identified with. It is possible for a group to have multiple operations, as long as they are well-defined and do not involve multiplying group elements. When proving that addition is closed with respect to a group, it is valid to assume multiplication as an operation and expand the definition of addition. However, this does not mean that the elements of the group are being multiplied, but rather the integers that make up the rational numbers. Overall, in a group, there is only one operation that is applied between elements, and it is important to specify which operation is being used when defining a group.
Gear300
1,213
To be sure of things, groups do not necessarily have to have only one operation; they may have more, but there is one and only one operation they are identified with. Am I right?
Mathematics news on Phys.org
There may be two operations o and * defined on a set G, such that (G, o) and (G, *) are both groups.
When we say "let G be a group" we're sloppy, you should say what the operation is.
Thus, if I were asked whether the set of all rational numbers Q with addition was a group, would it be valid to assume multiplication as an operation and state that a/b + c/d = (ad + cb)/(bd) ε Q (for a, b, c, d ε Z) in the case of proving that addition is closed with respect to Q.
Yes, that's valid, but you're not multiplying group elements (which would be bad). You're just expanding the definition of rational addition.
I see. Thanks for the replies.
Well, in general there is only one operation that is defined in a group. That is there is only one operation which is applied berween the elements of a group.
In your example, we could say let (Q,@) be a group, where Q is the set of rational numbers, and then we would say that @ is defined in this way:
[tex]\frac{a}{b} @ \frac{c}{d}=\frac{a*d+c*b}{b*d}[/tex]
where + is the natural addition symbol and * multiplication.
But, like it was said above, here you are not multiplying the elements of Q, which we have assumed are of the form
[tex]Q={ \frac{a}{b}: a,b \in Z }[/tex]
But in any case, in
[tex]\frac{a}{b}+ \frac{c}{d}= \frac{ad+ bc}{cd}[/tex]
You are NOT multiplying rational number you are multiplying integers.
What does it mean for a group to have only one operation?
In mathematics, a group is a set of elements that is closed under a single operation, typically denoted by *. This means that any two elements in the group can be combined using the operation to produce a third element, and that third element is also in the group.
Can a group have more than one operation?
Yes, a group can have multiple operations as long as they satisfy certain properties. These properties include closure (the result of the operation is always in the group), associativity (the order in which operations are performed does not matter), identity (there exists an element that when combined with any other element using the operation yields that same element), and inverse (every element has an inverse that when combined using the operation yields the identity element).
What are some examples of groups with more than one operation?
An example of a group with more than one operation is the set of real numbers under addition and multiplication. Another example is the set of 2x2 matrices with nonzero determinant under matrix multiplication.
Why is it important to understand that groups do not necessarily have only one operation?
Understanding that groups can have more than one operation helps us to explore more complex structures in mathematics. It also allows us to see connections between seemingly unrelated concepts and to generalize our understanding of groups.
Are there any limitations to groups having more than one operation?
Yes, there are certain restrictions on the operations that can be defined on a group. For example, the operations must be well-defined and satisfy the group properties mentioned earlier. Additionally, the operations must be compatible with each other, meaning that they must interact in a consistent and meaningful way.
  • Linear and Abstract Algebra
  • Quantum Physics
  • General Math
  • General Math
  • General Math
