Understanding Half Range Sine Series: A_0 Value and Theoretical Expectations
The discussion centers on the calculation of the coefficient \( a_0 \) in half range sine series for the function \( f(x) \). Participants clarify that \( a_0 \) must equal 0 for half range sine series, as it represents the odd extension of the function. The confusion arises from mistakenly applying the half range cosine series, which involves even extensions, leading to non-zero \( a_0 \) values. The correct approach is to utilize the half range sine series, which inherently results in \( a_0 = 0 \) due to the properties of odd functions.
  • Understanding of Fourier series, specifically half range sine and cosine series.
  • Knowledge of function extensions (even and odd) in Fourier analysis.
  • Familiarity with the properties of odd functions and their Fourier coefficients.
  • Basic calculus skills for evaluating integrals involved in Fourier series calculations.
  • Study the derivation of half range sine series coefficients, focusing on the integral calculations.
  • Explore the differences between even and odd function extensions in Fourier series.
  • Learn how to compute full range Fourier series for odd functions and their implications.
  • Review examples of half range sine series applications in signal processing and acoustics.
Mathematics students, educators, and professionals in engineering or physics who are working with Fourier series and need to clarify the distinctions between half range sine and cosine series.
foo9008
f(x) = x , 0 <x<1/2
1/2 , 1/2 < x <1
in this question , I am not convinced that a_ 0 = 0 for half range sine series , because i found that
but , thoerically , for half rang sine series , a_ 0 must be = 0 , ,am i right ? why the value of A- 0 that i got is not = 0 ? what's wrong with my working ?
Your calculation of ##a_0## is for the half range cosine series. It represents the even extension of your function. The half range sine series represents the odd extension of your function. They aren't the same thing.
sorry , can you explain further ? i did http://i.imgur.com/I5muGdJ.jpg
because i want to show that for half rang sine series , a_0 = 0 , however , i get the value of a_ 0 not equal to 0 ... what's wrong with my working ?
There is nothing wrong with your calculations. They are FS of different functions. If we call the even extension of your ##f(x)## by ##f_{even}(x)##, its equation on ##(-1,1)## is$$
f_{even}(x) = \left \{ \begin{array}{r,l}
\frac 1 2,&-1<x<-\frac 1 2\\
-x, & -\frac 1 2 < x < 0\\
x, & 0 < x < \frac 1 2 \\
\frac 1 2, &\frac 1 2 < x < 1
\end{array}\right .$$
Similarly, the odd extension ##f_{odd}(x)## is given by$$
f_{odd}(x) = \left \{ \begin{array}{r,l}
-\frac 1 2,&-1<x<-\frac 1 2\\
x, & -\frac 1 2 < x < \frac 1 2\\
\end{array}\right .$$These are both defined on ##(-1,1)## and of period ##2##. If you do the full range FS of ##f_{even}## you will find out that ##b_n=0## and you get only ##a_n## nonzero terms, and ##a_0## is what you have calculated. That's what the half range cosine series is.
If you expand ##f_{odd}## as a full range FS you will find all ##a_n = 0## and only ##b_n##'s are non-zero.
The half range formulas are just shortcuts for these two series taking advantage of the even and oddness. They are two different functions. But note they both represent the same thing on ##(0,1)##.
Likes foo9008
do you mean to get a_ 0 = 0 , we have to do the full range sine series ... so , we just need to follow the book stated that for half range sine series , a_ 0 = 0 ?
we wouldn't get a_ 0 = 0 if we do half range sine series only ?
You just need to understand that when you do a half range sine expansion of ##f(x)##, you are really doing the full range expansion of ##f_{odd}(x)##. But ##f_{odd}(x)## is an odd function, so its FS will have only nonzero ##b_n## and you don't have to calculate the ##a_n##. The advantage of using the half range formula for ##b_n## is that the integral only involves ##f(x)## so you don't have to figure out the full formula for ##f_{odd}(x)##.
Likes foo9008
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 47 ·
