Hallback Array Closed Loop Coil
The discussion focuses on the Halbach Array and its application in creating magnetic levitation (Maglev) systems. The user seeks information on closed loop coil configurations to optimize the Lorenz force for their project, which relies on gravity rather than propulsion. They note that while the Halbach Array can lift significant weight, the challenge lies in determining the correct coil setup to maximize efficiency. Suggestions include using aluminum or copper for the coils, with an emphasis on the need for the sled to reach a minimum speed for levitation. Overall, the conversation highlights the complexities of designing a gravity-based Maglev system and the lack of accessible resources on coil configurations.
Robin07
Hi all, I'm new to this forum and I'm not a physicist. I'm a Cabinet Maker looking for a career change.
I performed an advanced search on the entire site and was surprised to find not a mention in regards to Halbach Array. My understanding is that the special arrangement of nib magnets can lift 50 times its own weight. This arrangement is used in a fairly new application, amongst others, called "Maglev". The arrangement of the magnets are pretty straight forward. The specs or the means to figure out the closed loop coils used to facilitate the Lorenz force is very difficult to find. There must be a formula or means to measure the strength of a given magnet and from there calculate how to maximize the coil configuration so that the Lorenz force is at its peek. In the Maglev train application a linear motor is used to propel the train but in my application I will only need gravity much like an Olympic bob sled does.
Can any of you help me find the information I'm searching for or the means to be able to figure this out?
Thanks
Robin07
Halbach Array
Try searching for Halbach array (after Klaus Halbach). You'll find some discussion here and plenty more with Google.
And welcome to PF!
I second the Welcome to PF. Without even going to Doc's link, though, I think that I see a problem. If your design relies solely upon gravity, you can only run the thing downhill. There can be some coasting to some point up the next hill, but you can never exceed the height at which you start.
Like I mentioned, its the coil configuration that I'm having trouble finding any information on. I understand that aluminum is an option but copper would be the best material to use. The Halbach array induces a current which in turn creates an apposing magnetic field. The levitation only occurs when your sled is moving in excess of 2.5 km/hr. I've searched the web(Google) and read of the inductrack info extensively to find very little mentioned in regards to the coil setup.
Robin07
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
