Hamiltonian Function thru new Variables Q,P -- Show that Q is cyclic
The discussion centers on deriving the Hamiltonian function using new variables Q and P for a particle in a gravitational field. The user successfully determined the constant A as -1/2m^2g but struggles to express the Hamiltonian without the variable Q. Participants suggest that the user can eliminate Q by correctly formulating the Hamiltonian in terms of P and Q. A sign error in the user's calculation is pointed out, indicating the need for correction. The conversation emphasizes the importance of accurately expressing the Hamiltonian to achieve the desired cyclic nature of Q.
ardaoymakas
3b) Print out the Hamilton function using the new variables Q and P. Show that by choosing the appropriate constant A, the variable Q becomes cyclic and therefore the Hamilton function can be written down without Q.
H = (p^2/2m) + mgq
q = P - AQ^2 , p = - Q
I took the derviative of the Hamiltonian function with respect to Q and assumed that it was equal to 0 in order to find the Konstant A. I did find the Konstant A as -1/2m^2g but I still cant write the Hamiltonian equation without having the Q as a variable. Can someone please help?
Translation:
The Hamilton function for a particle moving vertically in a homogeneous gravitational field with gravitational constant g is given by
We introduced new variables Q and P. The variables q and p can be expressed by Q and P using the following transformation formulas:
a)Evaluate the Poisson bracket {Q ,P}q,p. Is the transformation canonical?
b)Print out the Hamilton function through the new variables Q and P. Show that by choosing a suitable constant A, the variable Q becomes cyclic and therefore the Hamilton function can be written down without Q.
Welcome to PF!
But posting attachments as pdf that have to be downloaded will hurt your response rate, particularly from those using iPads etc. Can you imbed the image?
haruspex said:
Welcome to PF!
Hey,
Thanks! Is this better?
Much better, thanks.
I've never worked with Hamiltonians, so not usually able to answer such a question, but it seems to me it is trivial to find the A which eliminates Q (and yes, it is the A you found). Just write out H in terms of P and Q. What does the Q term look like?
Edit: I see you have a sign error.
When I write it in terms of Q I get H = (-Q)^2 / 2m) + mgP + (Q^2)/2m which isnt the formula without Q
Did you note my edit? It says your expression for A has the wrong sign.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
