Hanging a sign Torque and summation of forces
The discussion centers on calculating the tension in guy wires and the forces acting on a beam supporting a 200 kg sign and a 155 N beam. The correct tension is derived using the torque equation, leading to a final tension of 1978 N, as opposed to the original calculation of 835 N. The horizontal force (Fh) is determined to be 836 N, while the vertical force (Fu) is calculated at 322 N. The key correction involves using the sine function for the lever arm in the torque calculation.
  • Understanding of static equilibrium principles
  • Familiarity with torque calculations in physics
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Ability to analyze free body diagrams
  • Study static equilibrium problems in physics
  • Learn about torque and its applications in engineering
  • Explore trigonometric functions in the context of physics
  • Review free body diagram techniques for complex structures
Students in physics or engineering courses, educators teaching statics, and professionals involved in structural analysis or mechanical design.
Jbreezy
Please help me confirm my answer.
A shop owner wants to hang a sign of mass 200 kg which is supported by which is supported by a uniform 155 N beam. What is the tension in the guy wires and the horizontal and vertical forces that the wall applies to the beam? The length of the beam is 400 cm.
The diagram shows that the angle between the guy wire and the beam is 65 degrees. It also shows that the wall to center of mass for the sign is 350 cm. I hope that gives a good picture.
Mb = mass of beam
r = distance
g = gravity
Ms = mass of sign
t = torque
T = tension
OK so sum the forces in each direction
Fy = Fu +Tsin(θ) - Mbg - Msg = 0
Fx = Fh - Tcos(θ) = 0
We will return back to the equations after we torque about the beam where it meets the wall.
Ʃt = Tr1 - Mbr2 +Msgr3
r1 = 4tan(65) 4 is in meters it is the length of the beam. Tan(65) is to find the lever arm.
r2 = 2 meters
r3 = 3.5 meters this is from the wall to the signs center of mass. The diagram shows this.
We solve for Tension and get
T = (Mbr2 +Msgr3) / (4tan(65))
T = (155N x 2) + (200kg x 9.8 m/s^2 x 3.5 m) /(4tan(65))
T = 835 N
Then put this back into the summation of forces to get the values for the Fh and Fu
I got .. Fh = 353.2 using Fh = Tcos(65)
And I got Fu = 1357 using Mb + Msg -Tsin(65)
I believe the missing diagram would looks like this (left hand side). Free Body diagram for the beam is shown on the right.
First thing to note is that in the problem statement the mass of the beam is given in Newtons and the mass of the sign is given in Kilograms so only the latter needs to be multiplied by g later. The OP spotted this.
Then we should make some assumptions/definitions: For forces, up and right is positive. For torques anti-clockwise is positive.
It's a statics problem, nothing is accelerating so the vertical forces sum to zero, the horizontal forces sum to zero and the torques sum to zero.
First vertical and horizontal forces..
ΣFy = Fu +Tsin(θ) - Mbg - Msg = 0 .....(1)
ΣFx = Fh - Tcos(θ) = 0......(2)
Correct so far.
I believe the OP missed out some brackets in that last line. The torque due to the mass of the sign and the mass of the beam should be in the same direction/same polarity so the equation should be..
Ʃt = Tr1 - (Mbr2 +Msgr3) = 0
The OP then states..
r2 = 2 meters
r3 = 3.5 meters this is from the wall to the signs centre of mass.
However I believe r1 = 4Sin(65) not 4tan(65). Perhaps my drawing is incorrect but the problem statement does say that..
So when I solve for Tension I get..
T = (Mbr2 +Msgr3) / (4sin(65))
T = ((155N x 2) + (200kg x 9.8 m/s^2 x 3.5 m)) /(4sin(65))
T = 1978N
Then substitute for T into equation (1) and (2) to get the values for the Fh and Fu
From eqn (1)..
Fh = Tcos(65)
= 1978cos(65)
= 836N
From eqn (2)..
Fu = Mb + Msg -Tsin(65)
= 155 + (200*9.8) - 1978sin(65)
= 155 + 1960 - 1793
= 322N
The method the OP used is correct but I believe the OP may have made a mistake calculating r1.
11K
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 21 ·
