Hard integrals for calculus 1-2 practice
  • Context: Undergrad
  • Thread starter Thread starter pakmingki
    Hard Integrals
194 replies · 212K views
Pranav-Arora said:
This one is fairly straightforward, use the substitution ##x=\tan\theta##.
For this one, define:
$$I(a)=\int_0^1 \frac{x^a-1}{\ln(x)}dx$$
Differentiate both the side with respect to a to get:
$$\frac{dI}{da}=\int_0^1 x^a\,dx=\frac{1}{a+1}$$
$$\Rightarrow I(a)=\ln|a+1|+C$$
It can be easily seen that C=0. We need the value of I(a) when a=1, hence,
$$I(1)=\ln(2)$$
We use the series expansion of ##\ln(1-x)## i.e
$$\ln(1-x)=-\sum_{k=1}^{\infty} \frac{x^k}{k}$$
Hence, our integral is:
$$-\int_0^1 \frac{1}{x}\sum_{k=1}^{\infty} \frac{x^k}{k}\,dx$$
$$=-\sum_{k=1}^{\infty} \int_0^1 \frac{x^{k-1}}{k}\,dx$$
$$=-\sum_{k=1}^{\infty} \frac{1}{k^2}=-\zeta(2)$$
Are you sure about the tan substitution? I couldn't solve it that way, but I'm not very good
Hi dumbperson! :)
Yes, I am sure about it. After the substitution, you should get:
$$I=\int_0^{\pi/4} \ln(1+\tan\theta)\,d\theta$$
Also,
$$I=\int_0^{\pi/4} \ln\left(1+\tan\left(\frac{\pi}{4}-\theta\right)\right)\,d\theta=\int_0^{\pi/4} \ln\left(1+\frac{1-\tan\theta}{1+\tan\theta}\right)\,d\theta=\int_0^{\pi/4} \ln(2)-\ln(1+\tan\theta) \,d\theta$$
$$\Rightarrow I=\frac{\pi \ln2}{4}-I \Rightarrow \boxed{I=\frac{\pi \ln2}{8}}$$
I hope that helps.
Reply
Pranav-Arora said:
Hi dumbperson! :)
Also,
I hope that helps.
Ah cool, thanks!
Not really a hard one but try this: [itex]\displaystyle\int 1-\sin x\cos x\tan x\,dx[/itex]
Some of my most memorable ones from calc I, should take a few coffees to solve:
$$\int_{0}^{∞} \frac{1}{x^2 + \sqrt{x}} dx$$
$$\int_{0}^{\frac{\pi}{4}} \frac{1}{1 + sin^2(x)} dx$$
if we divide both the numerator and the denominator by [itex]\frac{1}{cos^{2}x}[/itex] the integral becomes
[itex]\displaystyle\int_{0}^{\frac{\pi}{4}} \frac{sec^{2}x}{1+2tan^{2}x} dx[/itex]
We can make the substitution [itex]t = tan(x)[/itex]
I guess you can solve the first one by making the sub [itex]u = \sqrt{x}[/itex] and then using partial fractions decomposition
This one was a 1968 Putnam competition problem, I believe:
[tex]{\int_{0}^{1}{\frac{x^4 (1-x)^4}{1+x^2} dx}}[/tex]
The answer is really interesting...
If you're really up for a challenge, try this continuation:
[tex]{\int_{0}^{1}{\frac{x^8 (1-x)^8 (25+816x^2)}{3164(1+x^2)} dx}}[/tex]
These are just tedious and definitely easier than many of the problems here.
-- Joseph
The 1st one is not tedious:
[tex]- \int_{0}^{1} \frac{(1-x^4 -1)(1-x)^4}{1+x^2} dx = - \int_{0}^{1} (1-x)^5 (1+x) dx + \int_{0}^{1} \frac{(1-x)^4}{1+x^2} dx[/tex]
For the 1st integral, just sub 1-x = p and it will be trivial.
For the 2nd integral, write the integrand as
[tex]\frac{(1-x)^2 (1-x)^2}{(1-x)^2 + 2x} = (1-x)^2 - \frac{2x(1-x)^2}{(1-x)^2+2x} = (1-x)^2 - 2x\frac{1-x^2}{1+x^2} + \frac{4(1+x^2)-4}{1+x^2}[/tex]
The integration of the 4 terms is elementary.
Can you explain in more detail exactly what you did there please? I see that ##x^4 = -(-x^4 +1 - 1)## and then I don't see how you got to the next step.
I had a good time with this one:
[tex]\int_{\to 0}^{\to 1}\ln x \ln (1-x) \, \mathrm dx[/tex]
(+7 points if you prove that it exists before evaluating it)
$$\int_0^1 \ln x\ln(1-x)\,dx=-\sum_{k=1}^{\infty} \frac{1}{k}\int_0^1 x^k\ln x\,dx=\sum_{k=1}^{\infty} \frac{1}{k(k+1)^2}$$
$$=\sum_{k=1}^{\infty} \frac{1+k-k}{k(k+1)^2}=\sum_{k=1}^{\infty} \frac{1}{k(k+1)}-\sum_{k=1}^{\infty} \frac{1}{(k+1)^2}$$
Both the sums are easy to evaluate, the first one evaluates to 1 by telescoping series and the second one is simply ##\zeta(2)-1##, hence, the final answer is ##2-\zeta(2)##.
-- Joseph
http://en.wikipedia.org/wiki/Proof_that_22/7_exceeds_π
Reply
Not terribly hard but something I've found interesting
[tex]\int_{0}^{1}\sin (\ln(x)) dx[/tex]
This one is really easy. Sub [itex]x=e^y[/itex]. The rest is either that trick with the repeated integration by parts or transforming [itex]\sin y[/itex] to a complex exponential form.
I'm curious to see what technique you guys would use to solve ## \int_{-1}^{1} \frac{\cos(x)}{\exp(1/x) + 1}dx ##
ObsessiveMathsFreak said:
[tex]\int e^{-x^2} dx[/tex]
prasannapakkiam said:
how can this even be integrated?:rolleyes:
You don't. You use a power series for that one. Hahaha.
itsjustme said:
sin(2x)cos(2x)dx
[tex]\int{\sin{2x}\cos{2x}dx} = \frac{1}{2} \int{\sin{4x}} = -\frac{1}{8} \cos{4x}[/tex]
DyslexicHobo said:
I'm just out of Calc 1, so I'm not sure if I even have the knowledge to solve this... but here's where I am now. I can't tell if I complicated it even more, or if I'm closer to getting the solution.
[tex]\int (r-1)^{1/5}ln(r) - r^{-1} (r-1)^{1/5} dr[/tex]
I used u-substitution (well, r-substitution), where [tex]r = x^5 + 1[/tex]. After the substitution I used integration by parts, and now I'm unsure if that was even the right path. Please let me know!
And please tell us how to do [tex]\int_{0}^{\infty}sin(x^2)dx[/tex]
To integrate [tex]\int_{0}^{\infty}sin(x^2)dx[/tex] we use [tex]\int_{0}^{\infty}sin(x^n)dx[/tex] =[tex]\Gamma{(1 + \frac{1}{n})}\sin{\frac{\pi}{2n}}[/tex] = [tex]\frac{\sqrt{\pi}}{2\sqrt{2}}[/tex]
Reply
Zondrina said:
Give this one a chug:
$$\int x \sqrt{ax^2 + bx + c}$$
I would rewrite it as ##\displaystyle \frac{1}{2a}[\int(2ax + b)\sqrt{ax^2 + bx + c}dx - b\int\sqrt{ax^2 + bx + c}dx]##
The first integral is of the form ##\displaystyle \int f'(x)g(f(x))dx## and can be solved easily by either inspection or applying the sub##\displaystyle ax^2 + bx + c = u##.
The second integral is evaluated by completing the square and applying a hyperbolic sine sub.
Disclaimer: A friend told me about this and I do not know the answer yet.
Disclaimer 2: This is not really an integration problem but very close. (If you think it should not be here, please tell me, I will remove it)
Try this one,
(dy/dx) + 3 = (dy/dx) + 2
Apparently, it does have a solution (or so I am told and yes, I am still working on the problem)
Try this one,
Any vertical line (x=a) satisfies.
"∞ = ∞" :biggrin:
[itex]\displaystyle\int_0^\infty e^{-\sqrt[2015] x} dx = 2015![/itex]
True or false? Prove your answer. Came up with this one myself :D
That's true, I think. I'm lazy to do the maths, but you can make an obvious substitution, then use the definition of the Euler Gamma function.
This one isn't too hard, but it is really cool:
[itex]\int^{\infty}_{-\infty} \frac{1}{x^2 + 1} \, \mathrm{d}x[/itex]
Wouldn't it just be zero?
-You substitute x = tan u
-You get [arctan x] from (-inf) to (+inf) which is 0
