Harmonic Oscillator Problem (Classical, yet strangely quantum-like)
The harmonic oscillator problem discussed involves a mass of 1 g on a spring with a frequency of 1 Hz, yielding a quantum number of approximately n = 7.54594 x 1027. The eigenenergy formula used is En = ℏω0(n + 1/2), where ω0 = 2π Hz. Additionally, the average spacing between zeros of the eigenstate represented by the nth Hermite polynomial approaches zero as n increases, due to the polynomial roots diverging while being divided by a rapidly growing factorial term.
  • Understanding of quantum mechanics principles, specifically harmonic oscillators.
  • Familiarity with eigenenergy calculations and the formula En = ℏω0(n + 1/2).
  • Knowledge of Hermite polynomials and their properties in quantum mechanics.
  • Basic grasp of factorial growth and its implications in mathematical limits.
  • Study the derivation and applications of the harmonic oscillator model in quantum mechanics.
  • Learn about the properties and applications of Hermite polynomials in quantum systems.
  • Explore the implications of large quantum numbers on physical systems and their behavior.
  • Investigate the concept of eigenstates and their significance in quantum mechanics.
Students and professionals in physics, particularly those focused on quantum mechanics, as well as researchers exploring the mathematical foundations of quantum systems.
Domnu
Problem
A harmonic oscillator consists of a mass of 1 g on a spring. Its frequency is 1 Hz and the mass passes through the equilibrium position with a velocity of 10 cm/s. What is the order of magnitude of the quantum number associated with the energy of the system?
Solution?
Okay, so the eigenenergies associated with a harmonic oscillator are of the form
E_n = \hbar \omega_0 \left (n + \frac{1}{2}\right)​
So, here, we have that \omega_0 = 2\pi Hz. Now, we know that the energy of the system is (nonrelativistically, because the speeds are very small...)
1/2 m v^2 = 5 \cdot 10^{-6} J​
Now, we equate this with the eigenenergy formula, which gives us that the quantum number, n = 7.54594 \cdot 10^{27}, which is a ridiculously large number. So the magnitude would be \box{27}. Now I am guessing that such a large order of magnitude is fine since a one gram object (which is decently sized... say the density of water) in quantum mechanics is massive (like the size of the sun, compared to us). Is my answer, and more importantly, my method, correct?
Your method is correct and your numbers look fine. (I got 7.8 X10^27, but I rounded a little.)
Good job.:smile:
Very good. Thanks for verifying :smile:
Associated Problem
Here, let's say that the eigenstate corresponding to this function is \varphi_n. What is the average spacing between zeroes of an eigenstate with the quantum number of this problem?
Solution
We know that the quantum eigenstate of n is represented by
\varphi_n (x) = A_n \mathbb{H}_n e^{-\zeta^2 / 2}​
where \zeta = \beta x and \beta^2 = m\cdot \omega_0 / \hbar and \mathbb{H}_n denotes the nth Hermite polynomial. Now, we are just trying to find the spacing (in cm) of the zeros of nth Hermite polynomial as n goes to infinity (and of course, we divide this by sqrt(2^n * n! * sqrt(pi)) )... but wouldn't this grow arbitrarily close to zero as n approaches infinity? We can see this, because the roots of the Hermite polynomial get farther apart polynomially, but we are dividing the result by some higher-than-exponential order function (sqrt 2^n ...) So, the spacing in centimeters would be a number very close to zero (it may as well be zero in this case... we are dividing the spacing of the 10^28th Hermite polynomial by ((10^28)! * 2^28)... just as a comment, the number we are dividing by is unfathomably high... just as a statistic, the lower bound for its order of magnitude is (10^27)... not just 27. (oh my gods)
Is my above calculation correct?
  • · Replies 21 ·
