Solving Proton Transfer with Harmonic Oscillator
This discussion focuses on approximating proton transfer between water molecules using quantum mechanics, specifically through the use of harmonic potentials. The user initially approximates a transition state and encounters a challenge with their analytic eigenfunction, which results in a quadratic function. A solution is provided, demonstrating that a potential of the form V(x) = a*x^2 + b*x + c can be reexpressed as a harmonic potential by shifting the variable, thus maintaining the harmonic nature of the system.
  • Quantum mechanics fundamentals
  • Understanding of harmonic oscillators
  • Familiarity with wavefunctions
  • Basic calculus for variable transformation
  • Study the mathematical foundations of harmonic oscillators in quantum mechanics
  • Explore the concept of transition states in chemical reactions
  • Learn about variable transformations in quantum mechanics
  • Investigate the implications of potential energy functions in quantum systems
Researchers in quantum chemistry, physicists studying molecular dynamics, and anyone interested in the quantum mechanical modeling of chemical reactions.
greisen
Hi,
I am approximating a proton transfer from one water molecule to another. I would to have a quantum mechanical description of the proton transfer as a wavefunction. So I have approximated a "transition state" and use this as a harmonic potential. Then I get some energy values around this potential - the problem is that the best fit is still a quadratic function - so it should be harmonic but in my analytic eigenfunction I have x^2 - is it possible to use a*x^2 + b*x + c instead ?
Any help or advice appreciated.
Thanks in advance
Best regards
greisen said:
Hi,
Thanks in advance
Best regards
You can always reexpress a potential of the form V(x)= a x^2 + bx + c as a quadratic function the following way V(x) = a(x+ \frac{b}{2 a})^2 - \frac{ b^2}{4 a} + c
Now just shift the variable x' \equiv x - \frac{b}{2 a} and you get V(x') = a (x')^2 - \frac{ b^2}{4 a} + c Shifting th epotential by the constant piece leaves you with a harmonic potential in the new variable.
Hope this helps
Patrick
  • · Replies 16 ·
  • · Replies 21 ·
