Have you ever wondered about the physics of hydroplaning?
  • Thread starter Thread starter MillerGenuine
    Physics
Hydroplaning occurs when a layer of water builds up between a tire and the road, causing a loss of friction. This phenomenon happens because the tire cannot displace the water quickly enough, resulting in the tire effectively gliding on the water's surface. The key factor in hydroplaning is the tire's inability to maintain contact with the road, leading to a loss of control. Understanding this physics can help drivers recognize the dangers of driving in wet conditions. Overall, hydroplaning transforms tires into water-skis, significantly impacting vehicle handling.
MillerGenuine
Its really coming down outside so I am stuck inside with my mind roaming. I was curious about the physics behind a car hydroplaning. It seems to be just a loss of friction between the tires and the road...but mabe there is more to it? If anyone is up for discussion maybe you can help explain some physics behind it..
The trick to hydroplaning is that the tire is no longer in contact with the road. A layer of water forms between the tire and the road and tires essentially become water-skis. The water layer forms because the tire can't push the water out of the way fast enough.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
